[GRASS-dev] [GRASS GIS] #1503: parser error with db.select
trac at osgeo.org
Tue Dec 6 22:07:35 EST 2011
Reporter: hamish | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: LibGIS | Version: svn-trunk
Keywords: parser, db.select | Platform: Linux
Cpu: x86-64 |
NC2008 dataset in trunk:
GRASS7> db.select precip_30ynormals_g7 \
sql="select annual from precip_30ynormals_g7 where cat=2"
Description:
Selects data from attribute table (performs SQL query statement(s)).
Keywords:
database, attribute table, SQL
Usage:
db.select [-cdvt] [sql=string] [input=name] [table=name]
[database=name] [driver=name] [fs=character] [vs=character]
[nv=string] [output=name] [--overwrite] [--verbose] [--quiet]
ERROR: Option <sql> does not accept multiple answers
I guess it doesn't like the 'where cat=2'
`v.db.select where="cat=2"` seems ok though.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1503>
