[GRASS-dev] GRASS 6: GISRC on Windows
Maris Nartiss
maris.gis at gmail.com
Wed Dec 7 01:39:45 EST 2011
Seems that recent changes have broken something on Windows. This is
what I get when I try to start GRASS (WinGRASS-6.4.SVN-r49571-1) on
Vista (had to run from CMD to see anything and had to enable echo on
init.bat file):
C:\Users\tests>"C:\Program Files\GRASS 6.4.SVN\etc\echo" "GISDBASE: C:\Users\tes
ts" | g.dirseps -g 1>"C:\Users\tests\AppData\Roaming\GRASS6\grassrc6"
The system cannot find the path specified.
There is no "GRASS6" folder in C:\Users\tests\AppData\Roaming\.
Maris.
2011/12/4 Martin Landa <landa.martin at gmail.com>:
> Hi,
> 2011/12/3 Hamish <hamish_b at yahoo.com>:
>>> currently GIRC file is stored on Windows in
>>> $HOME/.grassrc6
>> hmmm, I thought that already had happened. I guess
>> not.
>>> This location seems to be probably quite weird
>>> for normal Windows user. I would suggest to store
>>> GISRC in `$APPDATA\GRASS6\rc`.
>> It seems like a good & natural idea to move it into
>> $APPDATA\GRASS6 on Windows -- but do keep the
>> 'grassrc6' name.
> done in r49506, build for testing available at [1].
> Martin
> [1] http://wingrass.fsv.cvut.cz/grass65/WinGRASS-6.5.SVN-r49506-1-Setup.exe
> Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
