[GRASS-dev] r3.in.xyz
Hamish
hamish_b at yahoo.com
Wed Dec 7 02:41:25 EST 2011
> Helena wrote:
> > has anybody considered writing r3.in.xyz?
> > It could be useful for analyzing multiple return lidar
> > point clouds and terrestrial lidar point clouds of vertical
> > features such as eroding stream banks.
> > I wanted to ask before we look into it here,
> yes, it is very easy; all you need to do is run r.in.xyz in
> a loop, iterating on the zrange=. It is easily accomplished
> with a wrapper script, no need to adjust (ie clutter) the C code.
> Stand by and I'll upload one to addons.
ok, done:
http://grass.osgeo.org/wiki/GRASS_AddOns#r3.in.xyz
if you have a multi-processor computer you can even run the import
of each vertical band in parallel using the workers= option, for a nice
speedup. (poor-man's technique)
see the help page for details on setting up the 3D region resolutions.
(can be tricky!)
> The only code change to consider is:
> - if (z < zrange_min || z > zrange_max) {
> + if (z < zrange_min || z >= zrange_max) {
> G_free_tokens(tokens);
> continue;
> so points falling exactly on the upper bound of the range
> are considered only once, and belong to the horizontal slice
> above the current one.
a solution has been implemented within the r3.in.xyz wrapper script,
no modifications to r.in.xyz are needed.
let me know if it works(!), and what sort of 3D interpolation could be
used to fill in the voids between the stars if a too-fine resolution
was used. (export to 3D vector then v.vol.rst?)
Hamish
