[GRASS-dev] Re: [GRASS GIS] #1503: parser error with db.select
trac at osgeo.org
Wed Dec 7 02:54:38 EST 2011
Reporter: hamish | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 6.5.0
Component: LibGIS | Version: svn-develbranch6
Keywords: parser, db.select | Platform: Linux
Cpu: x86-64 |
Changes (by hamish):
* version: svn-trunk => svn-develbranch6
Comment:
d'oh! the options got reordered..
I am not sure if this ticket should be closed as invalid, or if re-
ordering the primary option in 6.x should be considered a break in
backwards compatibility, although one that only bites those taking command
line shortcuts. If it is, devbr6 should be put back to its old way before
forgetting about this ticket.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1503#comment:3>
