[GRASS-dev] wxGUI: new packages layout
Martin Landa landa.martin at gmail.com
Thu Dec 8 08:21:40 EST 2011
Hi all,
2011/12/4 Martin Landa <landa.martin at gmail.com>:
> 2011/12/2 Markus Neteler <neteler at osgeo.org>:
>> The result will be the same GUI package layout in all active branches,
>> This I would definitely support.
> if no objections I will start wxGUI code reorganization in `devbr6` on
> Tuesday (6/12).
I started reorganization of wxGUI modules in r49621 (note that `make
distclean` is required). I hope to stabilize GUI in `devbr6` with few
next days. I would like to kindly ask you for testing the GUI a
reporting all errors you receive (ML is enough in this case).
Thanks, Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
