[GRASS-dev] GRASS extensions/addons mismatch
Martin Landa
landa.martin at gmail.com
Wed Dec 14 07:51:30 EST 2011
Hi all,
currently the GRASS AddOns extensions are installed on GNU/Linux to
$HOME/.grass<major_version>/addons
and on Windows to
$AppData\GRASS<major_version>\addons
This layout doesn't allow to install extensions for more installed
versions of GRASS. In other words, addons for GRASS 6.4.2 and GRASS
6.5 are installed on the same place
$HOME/.grass6/addons or $AppData\GRASS<major_version>\addons
I would suggest to change `addons` to `addons<full_version>`,
concretely GRASS 6.4.2 addons would be installed to
$HOME/.grass6/addons642 or $AppData\GRASS<major_version>\addons642
and GRASS 6.5 to
$HOME/.grass6/addons65 or $AppData\GRASS<major_version>\addons65
What do you think?
Other thing is that g.extension (or it's wxGUI front-end) should
automatically ask user to update his/her extensions when you upgrade
GRASS (libgis revision must be same for GRASS and the addons).
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
