[GRASS-dev] GRASS extensions/addons mismatch
Michael Barton Michael.Barton at asu.edu
Thu Dec 15 17:34:51 EST 2011
In preliminary tests (GRASS 6.4 svn release branch), this seems to work very well--and in fact considerably better than it does with GRASS 7/trunk at the moment. One of the extensions I test with consistently gives an install target not found error in trunk, but installs fine with 6.4 release branch.
BUT...
There remains some kind of weird problem with setting GRASS_ADDON_PATH.
By default, GRASS_ADDON_PATH is set to the desktop, followed by the various /Library and ~/Library paths. I can change it in the GRASS terminal and I can change it in the GUI, but if I use $GRASS_ADDON_PATH in g.extension, it STILL puts stuff into desktop (as the first path in $GRASS_ADDON_PATH). Moreover, I the changes made in GRASS_ADDON_PATH in the terminal do not show up when I display settings from the GUI and the changes made in GRASS_ADDON_PATH with the GUI do not show up in the terminal--and neither are registered by g.extension.
If I hard code the directory to which I want to install with g.extension, it puts stuff there. But the GRASS_ADDON_PATH is borked up on the Mac.
Michael
____________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Arizona State University
voice: 	480-965-6262 (SHESC), 480-727-9746 (CSDC)
fax:          480-965-7671 (SHESC),  480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
On Dec 14, 2011, at 11:12 PM, Hamish wrote:
> [by the way, I'd love to hear feedback from Mac users about how well
> g.extension(.sh) and the wxGUI extension manager performs in the latest
> 6.x.svn]
> Michael wrote:
>> The way that William had it set is
>> that the default locations for addons were defined as
>> /Library/GRASS/6.4 or /Library/GRASS/6.5 etc. The system
>> and/or user /Library folder is the normal place for
>> preferences, plugins, and other such files on a Mac. While
>> the Mac is Unix at heart, people don't interact with its OS
>> and file system in the same way Linux users do. If there are
>> things we want to hide from normal users, then using a
>> hidden directory is OK. But for addons, it is better to put
>> them in a place where users expect to find them. FWIW, it
>> would be better if preferences were in /Library too because
>> that's where they are for other software.
> fwiw, wrt the per-user ~/Library dir in Lion getting hidden, see:
>  http://osxdaily.com/2011/07/22/access-user-library-folder-in-os-x-lion/
> afaik the system-wide /Library is still world visible.
> Hamish
