[GRASS-dev] GRASS && OpenCV
Markus Metz markus.metz.giswork at googlemail.com
Sun Dec 18 13:46:14 EST 2011
On Sun, Dec 18, 2011 at 6:13 PM, Mohammed Rashad
<mohammedrashadkm at gmail.com> wrote:
> On Sun, Dec 18, 2011 at 9:13 PM, Martin Landa <landa.martin at gmail.com>
> wrote:
>> 2011/12/18 Mohammed Rashad <mohammedrashadkm at gmail.com>:
>> >> echo /usr/lib/grass64/lib >> /etc/ld.so.conf
>> >> ldconfig
>> > Hi Hamish
>> > I tried that but no luck :(
>> well, and are really GRASS libraries installed in `usr/lib/grass64` ? ;-)
> yes martin. I also installed grass 6.4.2 from source checkout
That was not Martin's question. Martin asked if the GRASS libraries
are really installed in `usr/lib/grass64`. By default, after `make
install`, libraries are installed in `$prefix/grass-6.4.2svn/lib`,
prefix would be `usr/local`on default. Please check again the
directory `$prefix/grass-6.4.2svn/lib`, optionally replacing $prefix
with your choice of prefix.
