[GRASS-dev] nasty v.db.dropcolumn and v.db.join bug in GRASS7 +
sqlite
Markus Neteler
neteler at osgeo.org
Mon Dec 19 00:13:15 EST 2011
On Sun, Dec 18, 2011 at 12:07 PM, Markus Metz
<markus.metz.giswork at googlemail.com> wrote:
> On Wed, Nov 30, 2011 at 10:24 PM, Dylan Beaudette
> <debeaudette at ucdavis.edu> wrote:
>> Just noticed a nasty bug when using v.db.dropcolumn and v.db.join with a
>> sqlite back-end. This seems to happen whenever a table is modified using the
>> 'coltypes' as reported by the GRASS-DB API:
> Please try trunk r49802.
> The bug was in the sqlite driver who assumes a default column length
> of 1 which is then adjusted according to the declared column type. A
> declared column type CHARACTER without length info slipped through
> with length = 1, although it is really a variable width TEXT field
> which gets a dummy width of 1000 for clients which don't understand
> variable-size fields.
Great for catching this. If it helps, I vote for backporting to 6.4 to
let it be in the upcoming 6.4.2 release.
Markus
