[GRASS-dev] [GRASS GIS] #1515: nviz fails to launch from the command line
GRASS GIS trac at osgeo.org
Mon Dec 19 02:21:07 EST 2011
 Reporter:  hamish   |       Owner:  grass-dev@…
     Type:  defect   |      Status:  new
 Priority:  blocker  |   Milestone:  6.4.2
Component:  Python   |     Version:  svn-releasebranch64
 Keywords:  nviz     |    Platform:  Linux
      Cpu:  x86-64   |
 something wrong with the module GUI magic in lib/python/task.py or
 gui/wxpython/gui_modules/menuform.py in 6.4svn:
 GRASS64svn> g.gisenv GRASS_GUI
 text
 GRASS64svn> nviz
 (popup window)
 Unable to fetch interface description for command 'nviz2.2_script'.
 Details: [Errno 2] No such file or directory
 Try to set up GRASS_ADDON_PATH variable.
 workaround: use the tcl/tk module gui, which works ok:
   g.gui tcltk -u -n
   nviz
 `nviz --ui` also fails in 6.4svn.
 `nviz --interface-description` works as expected, including module
 description.
 in devbr6 the module GUI launches, with or without `--ui`.
 in trunk `nviz --ui` works to bring up the module GUI.
 thanks,
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1515>
