[GRASS-dev] grass7 not compiling
Anna Kratochvílová
kratochanna at gmail.com
Mon Dec 19 10:42:00 EST 2011
I can't compile grass7, r49838
Anna
Errors in:
/usr/local/src/trunk/vector/v.rectify
anna at dell-desktop:/usr/local/src/trunk/vector/v.rectify$ make
gcc -g -Wall -Werror-implicit-function-declaration -fno-common
-Wextra -Wunused
-I/usr/local/src/trunk/dist.i686-pc-linux-gnu/include
-D_FILE_OFFSET_BITS=64 -DPACKAGE=\""grassmods"\"
-I/usr/local/src/trunk/dist.i686-pc-linux-gnu/include -o
OBJ.i686-pc-linux-gnu/main.o -c main.c
In file included from
/usr/local/src/trunk/dist.i686-pc-linux-gnu/include/grass/vect/digit.h:3,
from
/usr/local/src/trunk/dist.i686-pc-linux-gnu/include/grass/vector.h:4,
from main.c:23:
/usr/local/src/trunk/dist.i686-pc-linux-gnu/include/grass/vect/dig_structs.h:30:21:
error: ogr_api.h: No such file or directory
from
from main.c:23:
/usr/local/src/trunk/dist.i686-pc-linux-gnu/include/grass/vect/dig_structs.h:417:
error: expected specifier-qualifier-list before ‘OGRSFDriverH’
main.c: In function ‘main’:
main.c:121: warning: format not a string literal and no format arguments
main.c:123: warning: format not a string literal and no format arguments
main.c:137: warning: format not a string literal and no format arguments
main.c:182: warning: format not a string literal and no format arguments
main.c:208: warning: format not a string literal and no format arguments
main.c:246: warning: format not a string literal and no format arguments
make: *** [OBJ.i686-pc-linux-gnu/main.o] Error 1
