[GRASS-dev] grass7 not compiling
    Anna Kratochvílová
    kratochanna at gmail.com
    Mon Dec 19 10:54:38 EST 2011
2011/12/19 Markus Metz <markus.metz.giswork at googlemail.com>:
> 2011/12/19 Anna Kratochvílová <kratochanna at gmail.com>:
>> Hi,
>> I can't compile grass7, r49838
>> Anna
>> Errors in:
>> /usr/local/src/trunk/vector/v.rectify
> Please try r49839
It works now, thanks
Anna
> Markus M
>> anna at dell-desktop:/usr/local/src/trunk/vector/v.rectify$ make
>> gcc  -g -Wall -Werror-implicit-function-declaration -fno-common
>> -Wextra -Wunused
>> -I/usr/local/src/trunk/dist.i686-pc-linux-gnu/include
>> -D_FILE_OFFSET_BITS=64  -DPACKAGE=\""grassmods"\"
>> -I/usr/local/src/trunk/dist.i686-pc-linux-gnu/include -o
>> OBJ.i686-pc-linux-gnu/main.o -c main.c
>> In file included from
>> /usr/local/src/trunk/dist.i686-pc-linux-gnu/include/grass/vect/digit.h:3,
>>                 from
>> /usr/local/src/trunk/dist.i686-pc-linux-gnu/include/grass/vector.h:4,
>>                 from main.c:23:
>> /usr/local/src/trunk/dist.i686-pc-linux-gnu/include/grass/vect/dig_structs.h:30:21:
>> error: ogr_api.h: No such file or directory
>>                 from
>>                 from main.c:23:
>> /usr/local/src/trunk/dist.i686-pc-linux-gnu/include/grass/vect/dig_structs.h:417:
>> error: expected specifier-qualifier-list before ‘OGRSFDriverH’
>> main.c: In function ‘main’:
>> main.c:121: warning: format not a string literal and no format arguments
>> main.c:123: warning: format not a string literal and no format arguments
>> main.c:137: warning: format not a string literal and no format arguments
>> main.c:182: warning: format not a string literal and no format arguments
>> main.c:208: warning: format not a string literal and no format arguments
>> main.c:246: warning: format not a string literal and no format arguments
>> make: *** [OBJ.i686-pc-linux-gnu/main.o] Error 1
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-dev
