[GRASS-dev] [GRASS GIS] #1517: 'DateTime' not handled by v.in.ogr
GRASS GIS trac at osgeo.org
Wed Dec 21 05:22:00 EST 2011
 Reporter:  grasslandtom                   |       Owner:  grass-dev@…
     Type:  defect                         |      Status:  new
 Priority:  normal                         |   Milestone:  6.4.2
Component:  Database                       |     Version:  6.4.2 RCs
 Keywords:  v.in.ogr, DateTime, TIMESTAMP  |    Platform:  Unspecified
      Cpu:  Unspecified                    |
 steps to reproduce:
 _ create a table in PostGIS-database 'test':
 create table test (id INT, datetime TIMESTAMP);
 SELECT addgeometrycolumn('test', 'the_geom', 4030, 'POINT', 2);
 insert into test values (1, '2001-01-01 00:12:00', st_setsrid(ST_point(12,
 50), 4030));
 _ import in GRASS:
 v.in.ogr dsn='PG:dbname=test' out=test layer='test(the_geom)'
 location=new_test
 This raises the error
 DBMI-DBF driver error:
 SQL parser error: syntax error, unexpected NAME processing 'datetime'
 in statement:
 create table test (cat integer, datetime datetime, id integer)
 Error in db_execute_immediate()
 When the location is connected to PostGIS:
 _ import in GRASS
 v.in.ogr -o dsn='PG:dbname=test' out=test_out layer='test(the_geom)'
 raises the error
 DBMI-Postgres driver error:
 Cannot execute:
 create table test_out (cat integer, datetime datetime, id integer)
 FEHLER:  Typ »datetime« existiert nicht
 LINE 1: create table test_out (cat integer, datetime datetime, id in...
 (Sorry for the German error message. This one seems to come from the
 PostgreSQL Server which was running before I set the respective
 environment variables)
 When the location is connected to SQLite, the import works without a
 warning respective to DateTime but
 db.columns test_out
 raises
 WARNING: SQLite driver: unable to parse decltype: datetime
 WARNING: SQLite driver: column 'datetime', SQLite type 3 is not supported
 cat
 id
 Note that
 ogrinfo 'PG:dbname=test' 'test(the_geom)'
 gives in the last lines
 datetime: DateTime (0.0)
 OGRFeature(test(the_geom)):0
   datetime (DateTime) = 2001/01/01  0:12:00
   id (Integer) = 1
   POINT (12 50)
 Thus, DateTime seems to exist in OGR. Though the SQL data type is
 TIMESTAMP.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1517>
