[GRASS-dev] Re: [GRASS GIS] #718: r.li forgets mask/illegal filename
    trac at osgeo.org
    Fri Dec 23 07:54:59 EST 2011
 Reporter:  kyngchaos  |       Owner:  grass-dev@…
     Type:  defect     |      Status:  new
 Priority:  major      |   Milestone:  6.4.3
Component:  Raster     |     Version:  6.4.2 RCs
 Keywords:  r.li, smp  |    Platform:  All
      Cpu:  All        |
Changes (by lucadelu):
  * priority:  normal => major
  * version:  6.4.0 RCs => 6.4.2 RCs
  * milestone:  6.4.0 => 6.4.3
Comment:
 Replying to [comment:24 kyngchaos]:
 > I had trouble remembering what I did for the r.li.setup part.  I finally
 downloaded the NC data to try hamish's conf's.
 > The first one works fine, but hamish didn't have a problem with that
 either.
 > The next one gives an error (all jumbled from the multiple workers) and
 hangs (must ctl-c to exit):
 > > r.li.shannon map=landclass96 conf=test_conf2 out=test_shannon2
 > ERROR: ERROR: ProgramERROR:  error,Program worker()Program
 toReceive.type=0 error,
 > error,  worker()worker()  toReceive.type=24184648toReceive.type=0
 I have the same problem with 6.4.2 to test it I used nc, with the attached
 landsat_test file, copy it into ~/.r.li/history and after launch
 r.li.shannon map=lsat7_2002_40 conf=landsat_test out=landsat_shan
 Segmentation fault
 ERROR: Program error, worker() toReceive.type=0
Ticket URL: <https://trac.osgeo.org/grass/ticket/718#comment:25>
