[GRASS-dev] [GRASS GIS] #1522: dbm_base.py fails with multilayer
maps
trac at osgeo.org
Wed Dec 28 11:20:00 EST 2011
#1522: dbm_base.py fails with multilayer maps
Reporter: artegion | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 6.4.2
Component: wxGUI | Version: 6.4.2 RCs
Keywords: | Platform: All
Cpu: All |
map 'test' has two layers
Layer=1 Category=20 Table=net_table
Layer=2 Category=8 Table=links
File "c:/osgeo4w/usr/src/grass-6.4.2RC2/dist.i686-pc-
mingw32/etc/wxpython/gui_modules/mapdisp_window.py", line
1017, in MouseActions
1207, in OnLeftUp
mingw32/etc/wxpython/gui_modules/mapdisp.py", line 1382, in
QueryVector
mingw32/etc/wxpython/gui_modules/dbm_dialogs.py", line 102,
in __init__
mingw32/etc/wxpython/gui_modules/dbm_dialogs.py", line 360,
in UpdateDialog
File
"C:\Programmi\Grass\etc\wxpython\gui_modules\dbm_base.py",
line 109, in SelectByPoint
if self.tables[table][key]['ctype'] != types.StringType:
KeyError
'STATUS'
v.what works fine
>> ret = grass.read_command('v.what',
quiet = True,
flags = 'ag',
map = 'test',
east_north = '60.0,70.0',
distance = '1.0')
>> ret
East=60
North=70
Map=test
Mapset=piacenza
Type=Line
Id=20
Length=20.000000
Layer=1
Category=20
Driver=sqlite
Database=d:\gis_db\gauss-boaga\test_sqlite.db
Table=net_table
Key_column=cat
cat=20
net=
Layer=2
Category=8
Driver=sqlite
Table=links
Key_column=cat
cat=8
ID=12
LTYPE=1
NODE1=12
NODE2=13
LENGTH=5280
DIAMETER=10
ROUGHNESS=100
MLOSS=0
STATUS=Open
PARAMETERS=
TYPE=
SETTINGS=
TAG=ID12
but grass.vector_what puts Layer 2 attributes into Layer 1
>>data = grass.vector_what(map = 'test',coord = (60.0, 70.0), distance =
1.0)
>>data
[{'Category': 20,
'Map': 'test',
'Layer': 1,
'Key_column': 'cat',
'Database': 'd:\\gis_db\\gauss-boaga\\test_sqlite.db',
'Mapset': 'piacenza',
'Driver': 'sqlite',
'Length': '20.000000',
'Attributes': {'STATUS': 'Open',
'LTYPE': '1',
'PARAMETERS': '',
'DIAMETER': '10',
'SETTINGS': '',
'MLOSS': '0',
'cat': '8',
'LENGTH': '5280',
'TAG': 'ID12',
'NODE1': '12',
'NODE2': '13',
'TYPE': '',
'ID': '12',
'ROUGHNESS': '100'},
'Table': 'net_table',
'Type': 'Line',
'Id': 20}]
Ticket URL: <http://trac.osgeo.org/grass/ticket/1522>
