[GRASS-dev] [GRASS GIS] #1523: v.select segfaults with atype and btype area
GRASS GIS trac at osgeo.org
Wed Dec 28 11:23:24 EST 2011
 Reporter:  pertusus  |       Owner:  grass-dev@…
     Type:  defect    |      Status:  new
 Priority:  normal    |   Milestone:  7.0.0
Component:  Vector    |     Version:  svn-trunk
 Keywords:            |    Platform:  Linux
      Cpu:  x86-64    |
 If I do
 v.mkgrid map=continent_whole_grid grid=2,2
 v.mkgrid map=other_grid grid=4,4
 v.select ainput=other_grid atype=area binput=continent_whole_grid
 btype=area  output=result operator=overlap
 I get a segfault.  If one of atype or btype is not area, no segfault.
 Here is the backtrace
 (gdb) run
 Starting program: /usr/local/grass-7.0.svn/bin/v.select ainput=other_grid
 atype=area binput=continent_whole_grid btype=area output=result
 operator=overlap
 [Thread debugging using libthread_db enabled]
 Processing areas...
   18%
 Program received signal SIGSEGV, Segmentation fault.
 0x000000000040393f in select_lines (aIn=0x7fffffffcad0, atype=16,
 afield=1,
     bIn=<value optimized out>, btype=64, bfield=1, cat_flag=0, operator=8,
     relate=0x0, ALines=0x6aa1a0) at select.c:294
 294                                 if (line_overlap_area(aIn, aline,
 (gdb) bt
 #0  0x000000000040393f in select_lines (aIn=0x7fffffffcad0, atype=16,
     afield=1, bIn=<value optimized out>, btype=64, bfield=1, cat_flag=0,
     operator=8, relate=0x0, ALines=0x6aa1a0) at select.c:294
 #1  0x0000000000402f0e in main (argc=<value optimized out>,
     argv=<value optimized out>) at main.c:115
 I attach a tar that can be used to reproduce.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1523>
