[GRASS-dev] [GRASS GIS] #1527: vector projection over wrapping
boundary is split
trac at osgeo.org
Fri Dec 30 05:53:09 EST 2011
#1527: vector projection over wrapping boundary is split
Reporter: pertusus | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Vector | Version: svn-trunk
Keywords: | Platform: Linux
Cpu: x86-64 |
When I project a vector from a location thet overlaps with a wrapping
boundary of a map, the vector is split in two. For example, I have a
longitude latitude location covering the whole world, that wraps somewhere
in the Pacific (that is points on the eastern boundary are also on the
western boundary). When I project a vector constructed by doing a grid on
a Lambert equal area location centered somewhere in the Pacific, the grid
cells (that are, in that case, no more rectangular) that fall on the
boundary are cut in two, with warnings like:
WARNING: Number of centroids exceeds number of areas: 900 > 847
WARNING: Number of incorrect boundaries: 507
WARNING: Number of centroids outside area: 53
I attach a tarball to reproduce the issue (there is a png showing the
issue in the tarball too). The script to do everything (setup the lambert
location, and then the world map and do the png) is ./bug_wrap.sh.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1527>
