[GRASS-dev] Re: [GRASS GIS] #1527: vector projection over wrapping boundary is split
GRASS GIS trac at osgeo.org
Fri Dec 30 10:17:37 EST 2011
  Reporter:  pertusus  |       Owner:  grass-dev@…
      Type:  defect    |      Status:  closed
  Priority:  normal    |   Milestone:  7.0.0
 Component:  Vector    |     Version:  svn-trunk
Resolution:  fixed     |    Keywords:
  Platform:  Linux     |         Cpu:  x86-64
Changes (by pertusus):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 There are those compilation warnings with -Wall.
 main.c:54: attention : ‘src_box.N’ may be used uninitialized in this
 function
 main.c:54: attention : ‘src_box.S’ may be used uninitialized in this
 function
 main.c:54: attention : ‘src_box.E’ may be used uninitialized in this
 function
 main.c:54: attention : ‘src_box.W’ may be used uninitialized in this
 function
 main.c:54: attention : ‘tgt_box.W’ may be used uninitialized in this
 function
 The bug seems to be fixed for my reproducer case.  I will reopen if it
 doesn't fix my 'real world' case.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1527#comment:2>
