[GRASS-dev] Re: [GRASS GIS] #1525: r.mask cannot use float maps
GRASS GIS trac at osgeo.org
Sat Dec 31 05:26:16 EST 2011
 Reporter:  pertusus  |       Owner:  grass-dev@…
     Type:  defect    |      Status:  new
 Priority:  minor     |   Milestone:  7.0.0
Component:  Raster    |     Version:  svn-trunk
 Keywords:            |    Platform:  Linux
      Cpu:  x86-64    |
Comment(by pertusus):
 It does not solve my issue.  I have printed the options, and indeed
 maskcats is not null, but *:
 if __name__ == "__main__":
     options, flags = grass.parser()
     print options
 r.mask input=seed
 {'input': 'seed', 'maskcats': '*'}
 ERREUR :Raster map seed must be integer for maskcats parameter
 This is certainly because of the * below:
 #%option
 #% key: maskcats
 #% type: string
 #% description: Category values to use for mask (format: 1 2 3 thru 7 *)
 #% answer: *
 #% guisection: Create
Ticket URL: <http://trac.osgeo.org/grass/ticket/1525#comment:6>
