#1528: r.mapcalc within a FCELL mask cell_values_float: xdr_float failed
Reporter: pertusus | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Default | Version: svn-trunk
Keywords: | Platform: Linux
Cpu: x86-64 |
This is not a very reproducible bug, but intermitently reproducible. I do
a FCELL mask, with
r.circle output=circle10 coordinate=$x,$y min=0 max=10000
echo "$x|$y|1" | r.in.xyz input=- output=seed
r.patch input=seed,circle10 output=circle10_seed
and after the mask is set, a r.mapcalc gives:
r.mask circle10_seed
r.mapcalc "result_$nr = continent_fa - circle10_seed"
ERROR: cell_values_float: xdr_float failed for index 47
This is not so easily reproduced, to reproduce it I need the continent_fa
map which is a flow accumulation map from hydro1k...
I attach a tarball to reproduce the issue. First you need to run
./prepare_hydro1k.sh
which downloads using wget, and unpack.
Then you can test with
./lambert_map.sh
The r.mapcalc is in a loop because it doesn't error each time.
If the mask is CELL, for instance by using:
echo "$x|$y|1" | r.in.xyz input=- output=seed type=CELL
there is no error.
There is no such error with 6.4.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1528>
