[GRASS-dev] Re: ctypes problem with Vect_open_old
Martin Landa landa.martin at gmail.com
Thu Feb 3 10:14:23 EST 2011
2011/1/6 Glynn Clements <glynn at gclements.plus.com>:
> If this is happening when the ctypes wrappers and vector libraries are
> built at the same time, then we have a problem with our build system.
> If it's caused by mixing ctypes wrappers and vector libraries from
> different builds (e.g. PYTHONPATH pointing to a different version),
> then you need to prevent that.
unfortunately not sure how to fix it. What solution would you suggest?
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
