[GRASS-dev] Re: [GRASS GIS] #153: ps.map: support for placement by
% for decorations
trac at osgeo.org
Fri Feb 4 02:33:41 EST 2011
#153: ps.map: support for placement by % for decorations
Reporter: hamish | Owner: hamish
Type: enhancement | Status: assigned
Priority: major | Milestone: 6.5.0
Component: Ps.map | Version: svn-develbranch6
Keywords: ps.map | Platform: All
Cpu: All |
Changes (by hamish):
* cc: grass-dev@… (added)
* owner: grass-dev@… => hamish
* status: new => assigned
* priority: minor => major
Comment:
to help solve this issue for future a GUI front-end I plan on adding a -b
flag which will take the existing ps.map input file, run it to dynamically
place and size the map box, output the bounding box of the map box (in
inches), and then exit without creating a map.
output will be in the form `bbox=min_x,min_y,max_x,max_y` relative to the
top-left corner of the paper.
As long as the paper size is set, the GUI can then use this information
(and possibly g.region) to switch between %, inches, cm, mm, PostScript
points, and map units. The idea is that will be invisible to the user, all
they do is drag the decoration to where they'd like to see it.
IMO it is not practical or a good idea to have the python code mirror the
C code's placement logic itself (a lot of work/code to mimic, then a lot
of discipline to keep in sync).
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/153#comment:3>
