#1274: PostGIS load with v.in.ogr fails without -t
Reporter: arencambre | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.1
Component: Default | Version: 6.4.1 RCs
Keywords: | Platform: MSWindows 7
Cpu: x86-32 |
Comment(by arencambre):
'''db.connect -p''' returns this:
driver:pg
database:host=localhost,dbname=de
schema:
group:
So it's trying to connect to the same database.
This is a fresh install of GRASS 6.4.0, and I have never adjusted any
database connection settings. All I have done database-related is issue
the '''v.in.ogr''' command.
Since '''db.connect -p''' apparently it picked up
'''host=localhost,dbname=de''' from '''v.in.ogr''' , shouldn't it also get
the user id and password?
Ticket URL: <http://trac.osgeo.org/grass/ticket/1274#comment:2>
