[GRASS-dev] Re: [GRASS GIS] #1274: PostGIS load with v.in.ogr fails
without -t
trac at osgeo.org
Fri Feb 11 09:47:43 EST 2011
#1274: PostGIS load with v.in.ogr fails without -t
Reporter: arencambre | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.1
Component: Default | Version: 6.4.1 RCs
Keywords: | Platform: MSWindows 7
Cpu: x86-32 |
Comment(by arencambre):
Is this a fresh install of 6.4.0 or of 6.4.1?
Sorry for my delayed response. I tried with fresh installs of 6.4.0-1 and
6.4.1 RC1. Got the same result either way. I did not configure anything
related to a DBF file.
Regarding current 6.4.1, are you using the new wxGUI dialog
(File->Import vector data->Common import formats) or the original command
dialog which you get when clicking that button at the bottom of the new
dialog?
With 6.4.0-1, I was using the command dialog. In 6.4.1, I think I was
using the same dialog, although it was enhanced and had a multi-line
command entry with autocomplete.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1274#comment:4>
