[GRASS-dev] Re: compiling in osgeo4w - configure: error: *** Unable
to locate zlib library.
Jürgen E. Fischer
jef at norbit.de
Sat Feb 12 16:11:23 EST 2011
Hi Helmut,
On Sat, 12. Feb 2011 at 21:04:31 +0100, Helmut Kudrnovsky wrote:
> if i comment out line 112-114 of cpl_config.h:
> /* VC6 doesn't known intptr_t */
> #if (_MSC_VER <= 1200)
I suppose that should read
#if defined(_MSC_VER) && (_MSC_VER <= 1200)
to work with MinGW. Does the following patch work for you?
I'm unsure about the second hunk.
Index: cpl_config.h
--- cpl_config.h (revision 21697)
+++ cpl_config.h (working copy)
@@ -14,7 +14,7 @@
#define HAVE_VPRINTF 1
#define HAVE_VSNPRINTF 1
#define HAVE_SNPRINTF 1
-#if (_MSC_VER < 1500)
+#if defined(_MSC_VER) && (_MSC_VER < 1500)
# define vsnprintf _vsnprintf
#endif
#define snprintf _snprintf
@@ -100,7 +100,7 @@
#define lfind _lfind
-#if (_MSC_VER < 1310)
+#if defined(_MSC_VER) && (_MSC_VER < 1310)
# define VSI_STAT64 _stat
# define VSI_STAT64_T _stat
#else
@@ -109,7 +109,7 @@
#endif
-#if (_MSC_VER <= 1200)
+#if defined(_MSC_VER) && (_MSC_VER <= 1200)
typedef int intptr_t;
#endif
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-20
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
