[GRASS-dev] Re: [GRASS GIS] #1279: i.pca metadata truncated
GRASS GIS trac at osgeo.org
Tue Feb 15 06:33:35 EST 2011
 Reporter:  Barney2011             |       Owner:  grass-dev@…
     Type:  defect                 |      Status:  new
 Priority:  normal                 |   Milestone:  6.4.1
Component:  Default                |     Version:  6.4.0
 Keywords:  i.pca metadata r.info  |    Platform:  Linux
      Cpu:  x86-64                 |
Comment(by hamish):
 more from Rebecca:
 Here is the command (as created through the gui in GRASS7.0)
 i.pca
 input=1_jan_4789.1 at PERMANENT,1_jan_4789.10 at PERMANENT,1_jan_4789.11 at PERMANENT,\
 1_jan_4789.12 at PERMANENT,1_jan_4789.13 at PERMANENT,1_jan_4789.14 at PERMANENT,\
 1_jan_4789.2 at PERMANENT,1_jan_4789.3 at PERMANENT,1_jan_4789.4 at PERMANENT
 output=Jan_Pca_test
 Metadata file attached.
 I'm actually using the pca module for airborne spectral data (14 bands
 from the CASI2 sensor).
Ticket URL: <https://trac.osgeo.org/grass/ticket/1279#comment:2>
