[GRASS-dev] [GRASS GIS] #1280: problem about the output of g.parser
trac at osgeo.org
Wed Feb 16 11:38:07 EST 2011
Reporter: met | Owner: grass-dev@…
Type: defect | Status: new
Priority: minor | Milestone: 6.4.1
Component: Default | Version: 6.4.1 RCs
Keywords: g.parser output character | Platform: MSWindows XP
Cpu: OSX/Intel |
Into the output of command g.parser are eliminated all character slash \
while are keeping unotuched characters like / .
== GRASS 6.4.1RC1 (sanmarino)> test.parser
inp_file=D:\Modelli\nepaPy\Net3.inp
'@ARGS_PARSED@\nopt_inp_file=D:ModellinepaPyNet3.inp\n'
'opt_inp_file=D:ModellinepaPyNet3.inp'
{'inp_file': 'D:ModellinepaPyNet3.inp'} ==
inp_file=D:/Modelli/nepaPy/Net3.inp
'@ARGS_PARSED@\nopt_inp_file=D:/Modelli/nepaPy/Net3.inp\n'
'opt_inp_file=D:/Modelli/nepaPy/Net3.inp'
{'inp_file': 'D:/Modelli/nepaPy/Net3.inp'} ==
The problem come from by the Wxguy (under windows) that give back the
pathname using the wrong slash \.
Using commandline this problem can be solved putting the path name between
apexes " .
inp_file="D:\Modelli\epaPy\Net3.inp"
'opt_inp_file=D:\\Modelli\\epaPy\\Net3.inp'
{'inp_file': 'D:\\Modelli\\epaPy\\Net3.inp'} ==
Using the Guy insetad, that trick doesn't work.
== (Wed Feb 16 16:36:04 2011)
test.parser inp_file="C:\Programmi\GRASS-64\msys\m.ico"
'@ARGS_PARSED@\nopt_inp_file="C:ProgrammiGRASS-64msysm.ico"\n'
'opt_inp_file="C:ProgrammiGRASS-64msysm.ico"'
({'inp_file': '"C:ProgrammiGRASS-64msysm.ico"'}, {})
(Wed Feb 16 16:36:05 2011) Command finished (0 sec)
Again with the graphic guy, we can avoid this problem if the pathname has
blank ( even adding one blank at the end of file name)
== (Wed Feb 16 16:31:52 2011)
test.parser inp_file=C:\Programmi\GRASS-64\msys\m.ico
'@ARGS_PARSED@\nopt_inp_file=C:\\Programmi\\GRASS-64\\msys\\m.ico \n'
'opt_inp_file=C:\\Programmi\\GRASS-64\\msys\\m.ico '
({'inp_file': 'C:\\Programmi\\GRASS-64\\msys\\m.ico '}, {})
(Wed Feb 16 16:31:52 2011) Command finished (0 sec) ==
Ticket URL: <http://trac.osgeo.org/grass/ticket/1280>
