[GRASS-dev] v.generalize and LatLong?
Markus Neteler
neteler at osgeo.org
Fri Feb 18 16:38:35 EST 2011
On Thu, Feb 17, 2011 at 11:58 PM, Hamish <hamish_b at yahoo.com> wrote:
> Markus N wrote:
>> I wonder if v.generalize should work in LatLong? I tried to use the
>> displacement but the result is identical. Maybe a map unit (threshold
>> given in meters but currently considered in map units = degree?).
> did you run v.build.polylines first?
I tried, it does not make a difference. So LatLong will be the problem.
Markus
