[GRASS-dev] [GRASS GIS] #1283: PNG driver and Cairo driver mangle
large symbols, XDRIVER doesn't
trac at osgeo.org
Wed Feb 23 02:13:50 EST 2011
#1283: PNG driver and Cairo driver mangle large symbols, XDRIVER doesn't
Reporter: hamish | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 6.4.1
Component: Display | Version: svn-develbranch6
Keywords: | Platform: Linux
Cpu: x86-64 |
in GRASS 6.x the PNG driver and Cairo driver badly mangle large ring
symbols, while the XDRIVER doesn't. This makes the creation of
automated PNG plots on a headless server somewhat problematic,
unless the more tortuous ps.map + pstoimg method is used.
(note even though it's headless it still needs X.org installed, as a
dependency of the Cairo driver's X11-output option)
The PNG driver has an uneven inner/outer radius and gouges out of it; the
Cairo driver does not path the line segments together at all.
examples images attached.
cat << EOF > test.grf
width 30
symbol basic/circle 500 50 50 red none
EOF
d.mon x4
d.resize w=825 h=650
d.graph test.grf
d.out.file png_driver_ring
d.out.file -c cairo_driver_ring
In GRASS 7 the situation is a bit better, the PS and one of the PNG|cairo*
drivers(?) makes nice looking output, only complaint is that the closed
ring has a sliver where it isn't closed. could a special beginning==end
test be added to have it code the path?
Also, is it possible to double or quadruple the number of vertices in the
ring? At the current number it is very obviously a polygon and not a
circle.
width 30
EOF
export GRASS_WIDTH=825
export GRASS_HEIGHT=650
export GRASS_RENDER_IMMEDIATE=PNG
d.graph test.grf
export GRASS_RENDER_IMMEDIATE=CAIRO
d.graph test.grf
export GRASS_RENDER_IMMEDIATE=PS
export GRASS_PNGFILE=cairo_driver7_ring.ps
d.graph test.grf
[*] I'm not sure which driver it's using actually, I get an identical
output file for both. -- that is when setting 7's
GRASS_RENDER_IMMEDIATE=PNG doesn't make d.graph SegFault, while the cairo
driver doesn't. then I can tell.
[**] should "GRASS_RENDER_IMMEDIATE=cairo" be uppercase or not? the man
page shows both ways.
thanks,
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/1283>
