[GRASS-dev] Re: [GRASS-user] Warning to Mac users: TclTk 8.5.9 breaks compatibility for NVIZ
William Kyngesburye woklist at kyngchaos.com
Sat Feb 26 12:44:24 EST 2011
This really only applies to developers and users that compile GRASS.  I already bundle TclTk with my GRASS packages for those users that just download and intall the binaries.
Anyways, I added a TclTk 8.5.8 installer to my site for those that need it.  Just a quick standard Aqua framework build, it'll overwrite ActiveTcl, and it takes care of the lib symlinks mentioned in the GRASS Mac readme.
On Feb 26, 2011, at 10:20 AM, William Kyngesburye wrote:
> Don't upgrade to TclTk 8.5.9, stick with 8.5.8.  I realize it's been out since last September, but I never upgraded out of laziness and didn't notice.
> They switched to use the system Cocoa API from the old Carbon API (should have saved that for 8.6).  Togl still has Carbon calls in it, and I don't think that'll change (it's not an easy fix, and GRASS still uses the older togl 1.7, and even 2.0 still uses Carbon).  I'm too lazy to report a bug for TclTk on this - I don't use NVIZ and expect GRASS 7 (and maybe 6) to eventually have something working in Python anyways.
> Unfortunately, ActiveState, that makes the ActiveTcl that is recommended for compilation and my binaries, only provides old versions for download for the "business" edition, and doesn't allow reditribution of their installers.  I'll have to restore the TclTk compile instructions in the Mac readme in the GRASS source, and figure out something to make a TclTk 8.5.8 available for existing GRASS packages.
> Any user-compiled or other distribution of TclTk 8.5.8 Aqua frameworks should work, as it's all just standard options in the source.
> Note: this only affects NVIZ.  TclTk GUI is not affected.
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "I ache, therefore I am.  Or in my case - I am, therefore I ache."
> - Marvin
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
"The beast is actively interested only in now, and, as it is always now and always shall be, there is an eternity of time for the accomplishment of objects."
- the wisdom of Tarzan
