[GRASS-dev] compiling in osgeo4w - configure: error: *** Unable to
locate zlib library
Helmut Kudrnovsky
hellik at web.de
Sat Feb 26 19:25:18 EST 2011
>-----Ursprüngliche Nachricht-----
>Von: "Helmut Kudrnovsky"
>Gesendet: 27.02.2011 00:01:16
>very interesting that wingrass compiles without any error at your side, because
>I'm still getting an error in g.region:
>Errors in:
>/c/osgeo4w/usr/src/grass6_devel/general/g.region
>I can do make in the directory after compiling has finished.
now make in /general/g.region:
_________________________________________________________________________
syringia at NADA /c/osgeo4w/usr/src/grass6_devel
$ ./mswindows/osgeo4w/package.sh
GRASS GIS compilation log
Started compilation: Sat Feb 26 23:33:10 GMT 2011
Errors in:
In case of errors please change into the directory with error and run 'make'.
If you get multiple errors, you need to deal with them in the order they
appear in the error log. If you get an error building a library, you will
also get errors from anything which uses the library.
Finished compilation: Sun Feb 27 00:09:19 GMT 2011
$ cd general/g.region
syringia at NADA /c/osgeo4w/usr/src/grass6_devel/general/g.region
$ make
../../include/Make/Module.make:25: warning: overriding commands for target `install'
../../include/Make/Rules.make:90: warning: ignoring old commands for target `install'
gcc -I/c/osgeo4w/usr/src/grass6_devel/dist.i686-pc-mingw32/include -I/c/OSGeo4W/include -g -O2 -I/c/OSGeo4W/include -I/c/OSGeo4W/include -I/c/OSGeo4W/include -DPACKAGE=\""grassmods"\" -I/c/OSGeo4W/include -I/c/osgeo4w/usr/src/grass6_devel/dist.i686-pc-mingw32/include -o OBJ.i686-pc-mingw32/printwindow.o -c printwindow.c
printwindow.c:3:22: projects.h: No such file or directory
printwindow.c: In function `print_window':
printwindow.c:500: error: storage size of 'fact' isn't known
printwindow.c:587: error: `LP' undeclared (first use in this function)
printwindow.c:587: error: (Each undeclared identifier is reported only once
printwindow.c:587: error: for each function it appears in.)
printwindow.c:587: error: syntax error before "lp"
printwindow.c:588: error: `lp' undeclared (first use in this function)
printwindow.c:588: error: `iproj' undeclared (first use in this function)
printwindow.c:588: error: `fact' undeclared (first use in this function)
printwindow.c:591: error: `in_proj_info' undeclared (first use in this function)
printwindow.c:592: error: `in_unit_info' undeclared (first use in this function)
printwindow.c:596: error: `convergence' undeclared (first use in this function)
printwindow.c: At top level:
printwindow.c:606: error: syntax error before "if"
printwindow.c:613: error: syntax error before "if"
printwindow.c:622: error: syntax error before "if"
printwindow.c:632: warning: initialization makes integer from pointer without a cast
printwindow.c:632: error: initializer element is not constant
printwindow.c:632: warning: data definition has no type or storage class
printwindow.c:633: warning: initialization makes integer from pointer without a cast
printwindow.c:633: error: initializer element is not constant
printwindow.c:633: warning: data definition has no type or storage class
printwindow.c:635: error: syntax error before string constant
printwindow.c:635: warning: data definition has no type or storage class
printwindow.c:643: error: syntax error before string constant
printwindow.c:643: warning: data definition has no type or storage class
printwindow.c:644: error: syntax error before string constant
printwindow.c:644: warning: data definition has no type or storage class
printwindow.c:645: error: syntax error before string constant
printwindow.c:645: warning: data definition has no type or storage class
printwindow.c:650: warning: parameter names (without types) in function declaration
printwindow.c:650: warning: data definition has no type or storage class
printwindow.c:651: warning: parameter names (without types) in function declaration
printwindow.c:651: warning: data definition has no type or storage class
printwindow.c:652: warning: parameter names (without types) in function declaration
printwindow.c:652: warning: data definition has no type or storage class
printwindow.c:653: warning: parameter names (without types) in function declaration
printwindow.c:653: warning: data definition has no type or storage class
printwindow.c:674: error: `window' undeclared here (not in a function)
printwindow.c:674: warning: data definition has no type or storage class
printwindow.c:675: warning: data definition has no type or storage class
printwindow.c:676: error: syntax error before "if"
printwindow.c:679: error: initializer element is not constant
printwindow.c:679: warning: data definition has no type or storage class
printwindow.c:680: error: initializer element is not constant
printwindow.c:680: warning: data definition has no type or storage class
printwindow.c:682: error: redefinition of 'latitude'
printwindow.c:674: error: previous definition of 'latitude' was here
printwindow.c:682: warning: data definition has no type or storage class
printwindow.c:683: error: redefinition of 'longitude'
printwindow.c:675: error: previous definition of 'longitude' was here
printwindow.c:683: warning: data definition has no type or storage class
printwindow.c:684: error: syntax error before "if"
printwindow.c:687: error: initializer element is not constant
printwindow.c:687: warning: data definition has no type or storage class
printwindow.c:688: error: initializer element is not constant
printwindow.c:688: warning: data definition has no type or storage class
printwindow.c:690: error: redefinition of 'latitude'
printwindow.c:682: error: previous definition of 'latitude' was here
printwindow.c:690: warning: data definition has no type or storage class
printwindow.c:691: error: redefinition of 'longitude'
printwindow.c:683: error: previous definition of 'longitude' was here
printwindow.c:691: warning: data definition has no type or storage class
printwindow.c:692: error: syntax error before "if"
printwindow.c:695: error: initializer element is not constant
printwindow.c:695: warning: data definition has no type or storage class
printwindow.c:696: error: initializer element is not constant
printwindow.c:696: warning: data definition has no type or storage class
printwindow.c:698: error: redefinition of 'latitude'
printwindow.c:690: error: previous definition of 'latitude' was here
printwindow.c:698: warning: data definition has no type or storage class
printwindow.c:699: error: redefinition of 'longitude'
printwindow.c:691: error: previous definition of 'longitude' was here
printwindow.c:699: warning: data definition has no type or storage class
printwindow.c:700: error: syntax error before "if"
printwindow.c:703: error: initializer element is not constant
printwindow.c:703: warning: data definition has no type or storage class
printwindow.c:704: error: initializer element is not constant
printwindow.c:704: warning: data definition has no type or storage class
printwindow.c:707: error: syntax error before "if"
printwindow.c:752: error: syntax error before '(' token
printwindow.c:752: error: conflicting types for 'libintl_fprintf'
printwindow.c:752: note: a parameter list with an ellipsis can't match an empty parameter name list declaration
c:/OSGeo4W/include/libintl.h:307: error: previous declaration of 'libintl_fprintf' was here
printwindow.c:753: error: syntax error before '(' token
printwindow.c:754: error: syntax error before '(' token
printwindow.c:755: error: syntax error before '(' token
printwindow.c:757: error: syntax error before '(' token
printwindow.c:762: error: syntax error before '(' token
printwindow.c:763: error: syntax error before numeric constant
printwindow.c:763: warning: data definition has no type or storage class
printwindow.c:764: error: syntax error before '(' token
printwindow.c:765: error: syntax error before numeric constant
printwindow.c:765: warning: data definition has no type or storage class
printwindow.c:766: error: syntax error before '(' token
printwindow.c:767: error: syntax error before numeric constant
printwindow.c:767: warning: data definition has no type or storage class
printwindow.c:768: error: syntax error before '(' token
printwindow.c:769: error: syntax error before '(' token
printwindow.c:771: error: syntax error before '(' token
printwindow.c:772: error: syntax error before '(' token
printwindow.c:774: error: syntax error before '(' token
make: *** [OBJ.i686-pc-mingw32/printwindow.o] Error 1
all tested with develbranch_6 at r45468
>just to be sure, projects.h isn't there after Jürgens clean-up of osgeo4w in
>your C:\OSGeo4W\include ?
best regards
Helmut
Empfehlen Sie WEB.DE DSL Ihren Freunden und Bekannten und wir
belohnen Sie mit bis zu 50,- Euro! https://freundschaftswerbung.web.de
