[GRASS-dev] [GRASS GIS] #1253: wingrass7 - i.aster.toar - compiling error
GRASS GIS trac at osgeo.org
Sat Jan 1 16:42:07 EST 2011
 Reporter:  hellik             |       Owner:  grass-dev@…
     Type:  defect             |      Status:  new
 Priority:  normal             |   Milestone:  7.0.0
Component:  Compiling          |     Version:  svn-trunk
 Keywords:  wingrass, imagery  |    Platform:  MSWindows Vista
      Cpu:  x86-32             |
 r44815 self compiled in the osgeo4w-stack
 during compilation, a windows error message pops up (grass7 isn't
 working), after clicking ok, compilation continues.
 i.aster.toar.exe is compiled, but i.aster.toar.html isn't created.
 GRASS GIS compilation log
 Started compilation: Thu Dec 30 21:51:01 GMT 2010
 Errors in:
 /c/osgeo4w/usr/src/grass_trunk/lib/vector/diglib
 /c/osgeo4w/usr/src/grass_trunk/imagery/i.aster.toar
 In case of errors please change into the directory with error and run
 'make'.
 If you get multiple errors, you need to deal with them in the order they
 appear in the error log. If you get an error building a library, you will
 also get errors from anything which uses the library.
 Finished compilation: Thu Dec 30 23:33:48 GMT 2010
 syringia at NADA /c/osgeo4w/usr/src/grass_trunk/imagery/i.aster.toar
 $ make
 if [ "/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-
 mingw32/bin/i.aster.toar.exe" != "" ] ; then
 GISRC=/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-
 mingw32/demolocation/.grassrc70
 GISBASE=c:/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32
 PATH="/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/bin:$PATH"
 PYTHONPATH="c:/osgeo4w/usr/src/grass_trunk/dist.i686-pc-
 mingw32/etc/python;$PYTHONPATH"
 mingw32/bin:/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-
 mingw32/lib:/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-
 mingw32/lib:.:/usr/local/bin:/mingw/bin:/bin:/osgeo4w/bin:/c/windows/system32:/c/windows:/c/windows/System32/Wbem:/c/Program
 Files/ATI Technologies/ATI.ACE/Core-Static:/c/Program
 Files/ActivIdentity/ActivClient/:/c/Program Files/Hewlett-
 Packard/IAM/bin:/c/Program Files/Common Files/Roxio
 Shared/DLLShared/:/c/Program Files/Common Files/Roxio
 Shared/10.0/DLLShared/:/c/windows/System32/WindowsPowerShell/v1.0/:/c/Program
 Files/TortoiseSVN/bin:/c/Program Files/QuickTime/QTSystem/:/bin" LC_ALL=C
 /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/bin/i.aster.toar.exe
 --html-description < /dev/null | grep -v '</body>\|</html>' >
 i.aster.toar.tmp.html ; fi
 make: *** [i.aster.toar.tmp.html] Error 1
 rm i.aster.toar.tmp.html
 then GISRC=/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-
 /c/Program Files/ActivIdentity/ActivClient/:/c/Program Files/Hewlett-
 Packard/IAM/bin:/c/Program Files/Common Files/Roxio Shared/DLLShared/:
 /c/Program Files/TortoiseSVN/bin:/c/Program Files/QuickTime/QTSystem/:
 /bin"
 LC_ALL=C
 --html-description
 < /dev/null | grep -v '</body>\|</html>' > i.aster.toar.tmp.html ; fi
Ticket URL: <http://trac.osgeo.org/grass/ticket/1253>
