[GRASS-dev] How many points in a point layer and v.surf.bspline questions
Doug_Newcomb at fws.gov Doug_Newcomb at fws.gov
Mon Jan 3 08:26:49 EST 2011
Hi Folks,
I aggregated all of the bare earth lidar points for the state of North
Carolina into a single file  Imported all 8.5 billion points for NC into
one point layer with no topology.  I was sort of curious to see if I could
generate a seamless 20 ft elevation grid for the State of North Carolina
from a single data layerusing bspline and  tried the following command:
GRASS 6.5.svn (ncstpft_nad83):~ > v.surf.bspline input=all_nc_be_pts2
raster=all_nc_be_20ft_bspline sie=40 sin=40 layer=0
WARNING: Coor files of vector map <all_nc_be_pts2 at statewide> is larger
than
         it should be (158913789952 bytes excess)
Cells for raster map <all_nc_be_20ft_bspline> will be interpolated
ERROR: G_calloc: unable to allocate 18446744071812941729 * 8 bytes of
       memory at dalloc.c:66
This was for a region with the following settings:
projection: 99 (Lambert Conformal Conic)  - North Carolina State Plane
Feet NAD83
zone:       0
datum:      nad83
ellipsoid:  grs80
north:      1050000
south:      30000
west:       400000
east:       3060000
nsres:      20
ewres:      20
rows:       51000
cols:       133000
cells:      6783000000
I then zoomed into the northeast corner of the state and set the region to
north:      1047363
south:      795102
west:       2505067
east:       3007693
nsres:      20.00007928
ewres:      20.00023875
rows:       12613
cols:       25131
cells:      316977303
and tried again for this area
raster=ne_nc_be_20ft_bspline sie=40 sin=40 layer=0
than
Cells for raster map <ne_nc_be_20ft_bspline> will be interpolated
subregion 1 of 5459
I killed that one and set the sin and sie to 400 rather than 40 .  This
dropped the regions down to 66.
raster=ne_nc_be_20ft_bspline sie=400 sin=400 layer=0
than
subregion 1 of 66
This is about halfway done, so I should see the results in another 1.5
days or so.
I have two questions.  First, is there a problem with importing large
point datasets that is being highlighted by the warning?  I did notice
that the size of the coords and hist files did not match for the point
data set.
        Second,  is about v.surf.bspline and sin and sie.  I have seen in
the documentation that the sie an sin needs to be twice as large as the
spacing between points as a good starting point.   The density of the
lidar data sets that make up this ground point layer varies between 1m and
5 m .   Obviously, making sin and sie larger reduces the number of
subregions, but how does that affect the accuracy of the surface
generated?  If I'm trying to generate a 20ft grid, is using sin and sie
options of 400 absurd?  ( I.E.,  It works faster but the results are less
accurate)
The version of GRASS used was the weekly snapshot from 12/25/2010.  The
computer has a 1.6 GHz Xeon quad-core cpu with 16 GB RAM.
Doug
Doug Newcomb
USFWS
Raleigh, NC
919-856-4520 ext. 14 doug_newcomb at fws.gov
The opinions I express are my own and are not representative of the
official policy of the U.S.Fish and Wildlife Service or Dept. of the
Interior.   Life is too short for undocumented, proprietary data formats.
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20110103/7133b3bf/attachment.html
