[GRASS-dev] Re: [GRASS GIS] #1251: tweaking new feature in file
selection drop-down of layer manager
trac at osgeo.org
Mon Jan 3 12:23:53 EST 2011
#1251: tweaking new feature in file selection drop-down of layer manager
Reporter: cmbarton | Owner: martinl
Type: defect | Status: reopened
Priority: normal | Milestone: 6.4.1
Component: wxGUI | Version: svn-trunk
Resolution: | Keywords: map selection
Platform: Unspecified | Cpu: Unspecified
Comment(by cmbarton):
Replying to [comment:10 annakrat]:
> Replying to [comment:9 cmbarton]:
> > Type something while map list is displayed -> nothing happens
> Sorry, I tried to change this behaviour but unsuccessfully, there are
some problems with events. So it's necessary to close the popup to type
anything.
> There are some other features you haven't described, you can display
popup with down arrow. Then it's possible to change selection with arrows,
tab changes selection to map (starting with typed letters) in the next
mapset, enter confirms the selection and closes the popup. Don't be
surprised that the action is performed after releasing the key (and not
pressing down), it's the same problem I mentioned before.
> Anna
The features you mention do not work on my Mac.
The down arrow does open the popup, but arrows do not work after that. I
assume that the binding for opening the popup has trapped all arrow
function. Most people would probably like to have the arrows available to
move up and down the map list.
The tab key just switches back and forth between the entry box and the
page tabs at the top of the dialog.
Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/1251#comment:13>
