[GRASS-dev] Re: [GRASS GIS] #1254: v.build error (was: v.extract
and v.build errors)
trac at osgeo.org
Tue Jan 4 01:48:17 EST 2011
Reporter: akbgf | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Vector | Version: svn-trunk
Keywords: v.build | Platform: Linux
Cpu: x86-32 |
Changes (by akbgf):
* keywords: v.build, v.extract => v.build
Comment:
Replying to [comment:3 martinl]:
> Replying to [comment:2 akbgf]:
> > After that I received the error message: [[BR]]
> > ERROR: Unable to open vector map <tmpa at CHRIS> on level 2. Try to
rebuild vector topology by v.build.
> Can you reproduce this behaviour with data from spearfish or nc_spm_08?
[[BR]]
Hi!
GRASS-7.0 r44852 [[BR]]
spearfish_grass60data-0.3.tar.gz
v.what --v -a map=fields at PERMANENT east_north=594220.710280,4924144.962617
distance=238.345865 [[BR]]
ERROR: You must build topology on vector map <fields at PERMANENT> [[BR]]
v.build map=fields at PERMANENT --overwrite [[BR]]
Building topology for vector map <fields at PERMANENT>... [[BR]]
Registering primitives... [[BR]]
271 primitives registered [[BR]]
1627 vertices registered [[BR]]
Building areas... [[BR]]
65 areas built [[BR]]
11 isles built [[BR]]
Attaching islands... [[BR]]
Attaching centroids... [[BR]]
Number of nodes: 217 [[BR]]
Number of primitives: 271 [[BR]]
Number of points: 0 [[BR]]
Number of lines: 0 [[BR]]
Number of boundaries: 208 [[BR]]
Number of centroids: 63 [[BR]]
Number of areas: 65 [[BR]]
Number of isles: 11 [[BR]]
Number of areas without centroid: 2 [[BR]]
(Tue Jan 4 08:36:30 2011) Command finished (0 sec) [[BR]]
v.what --v -a map=fields at PERMANENT east_north=594266.355140,4924611.214953
distance=238.095238 [[BR]]
In the /var/log/messages I have:
Jan 4 08:36:30 scorpion kernel: v.build[31129]: segfault at 2c ip
0804922b sp bffd2240 error 4 in v.build[8048000+2000]
Andres Kuusk [[BR}
Tartu Observatory, Estonia
Ticket URL: <http://trac.osgeo.org/grass/ticket/1254#comment:4>
