[GRASS-dev] Re: [GRASS GIS] #1254: v.build error
trac at osgeo.org
Tue Jan 4 04:19:04 EST 2011
Reporter: akbgf | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Vector | Version: svn-trunk
Keywords: v.build | Platform: Linux
Cpu: x86-32 |
Comment(by mmetz):
Replying to [comment:6 akbgf]:
> Replying to [comment:5 martinl]:
> > can you post some debug info?
> > gdb v.build
> > run map=field
> > More info at http://grass.osgeo.org/wiki/GRASS_Debugging
> Some debug info is in the attached file debug04012011.log.
I see some suspicious settings in the debug log:
show env shows LOCATION_NAME and MAPSET, but not GISDBASE. Further on, I
think that LOCATION_NAME, MAPSET, and GISDBASE are usually not visibly
with show env, but can usually be shown with g.gisenv, if grass is started
by running grass70. If you have set all environment variables required by
grass manually, you also need to set GISDBASE.
Then there is
LD_LIBRARY_PATH=/wrk/andres/sw/linux/suse11/src/grass70/grass_trunk/dist.i686
-pc-linux-
gnu/lib:/usr/lib/mpi/gcc/openmpi/lib:/wrk/andres/sw/linux/suse11/bin/MonitorSoftware/lib:/wrk/andres/sw/linux/suse11/bin/MonitorSoftware/lib
GISBASE=/home/grass
PWD=/wrk/andres/sw/linux/suse11/src/grass70/grass_trunk/dist.i686-pc-
linux-gnu/bin
which is strange because GISBASE is supposed to be the location of your
grass installation, but it does not match LD_LIBRARY_PATH. Any reason why
PWD is in the bin directory of the source build? Once grass is initialized
properly, you can run grass modules from anywhere.
I guess that GISBASE and LD_LIBRARY_PATH should be either
-pc-linux-
GISBASE=/wrk/andres/sw/linux/suse11/src/grass70/grass_trunk/dist.i686-pc-
linux-gnu
or
LD_LIBRARY_PATH=/home/grass/lib:/usr/lib/mpi/gcc/openmpi/lib:/wrk/andres/sw/linux/suse11/bin/MonitorSoftware/lib:/wrk/andres/sw/linux/suse11/bin/MonitorSoftware/lib
GISBASE=/home/grass
in case you have installed grass to /home/grass.
Finally,
GISRC=/wrk/andres/.grass7/rc
looks suspicious because grass7 uses a temporary copy of rc, usually
located in something like
GISRC=/tmp/grass7-<user name>-<pid>/gisrc
(side note to devs: why not in the grass .tmp directory ?)
Altogether, it seems that grass is not started properly.
Markus M
Ticket URL: <http://trac.osgeo.org/grass/ticket/1254#comment:7>
