[GRASS-dev] Re: [GRASS-SVN] r44857 - grass/trunk/lib/vector/diglib
Markus Metz
markus.metz.giswork at googlemail.com
Tue Jan 4 05:22:55 EST 2011
On Tue, Jan 4, 2011 at 11:17 AM, Martin Landa <landa.martin at gmail.com> wrote:
> Hi,
> the commit seems to be incomplete
Should be fixed in r44862. (You were faster updating than I was committing;-))
> martin at pierre:~/src/grass_trunk/lib/vector/diglib$ make
> gcc -g -Wall -Werror-implicit-function-declaration -fno-common
> -Wextra -Wunused -fPIC
> -I/usr/local/src/grass_trunk/dist.i686-pc-linux-gnu/include
> -D_FILE_OFFSET_BITS=64 -I/usr/local/include -I/usr/local/include
> -DPACKAGE=\""grasslibs"\"
> -I/usr/local/src/grass_trunk/dist.i686-pc-linux-gnu/include -o
> OBJ.i686-pc-linux-gnu/spindex.o -c spindex.c
> OBJ.i686-pc-linux-gnu/type.o -c type.c
> OBJ.i686-pc-linux-gnu/update.o -c update.c
> spindex.c: In function ‘dig_spidx_init’:
> spindex.c:43: error: ‘struct Plus_head’ has no member named ‘Spidx_file’
> make: *** [OBJ.i686-pc-linux-gnu/spindex.o] Error 1
> Martin
> Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
