[GRASS-dev] Re: ctypes problem with Vect_open_old
Martin Landa
landa.martin at gmail.com
Tue Jan 4 05:47:44 EST 2011
2011/1/4 Martin Landa <landa.martin at gmail.com>:
>> The map is opened correctly, Vect_level() works. Anyway
>> Vect_write_line() fails, seems to be that Map_info is corrupted. No
>> clue at this moment.
> when tracking pointer address of Map_info instance -
> Vect_open_update() and Vect_level() points to the same address.
> Pointer to Map differs in Vect_write_line(), no idea where the pointer
> is being corrupted.
strangely e.g. Vect_delete_line() works...
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
