[GRASS-dev] Re: [GRASS GIS] #1257: Georectifier is broken
GRASS GIS trac at osgeo.org
Fri Jan 14 11:09:50 EST 2011
 Reporter:  cmbarton      |       Owner:  grass-dev@…
     Type:  defect        |      Status:  new
 Priority:  blocker       |   Milestone:  6.4.1
Component:  wxGUI         |     Version:  unspecified
 Keywords:  georectifier  |    Platform:  Unspecified
      Cpu:  Unspecified   |
Comment(by cmbarton):
 Did you test on 6.5 or only 6.4.0 (which I didn't test)?
 Could be that this is Mac only, since I first heard about if from a
 colleague using a Mac. Then I tested and had the same problems.
 Doesn't seem like a Mac problem given the error, however. The variable
 self.height is not being set, triggering a divide by zero error. Where is
 self.height coming from in this case?
 Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/1257#comment:3>
