[GRASS-dev] Re: [GRASS-SVN] r45036 - grass/branches/develbranch_6/vector/v.out.ogr
Benjamin Ducke benjamin.ducke at oxfordarch.co.uk
Fri Jan 14 18:02:41 EST 2011
OK, committed to and test in GRASS 7.
All seems to work smoothly as far as I can tell, but please test.
Note that I have also implemented the "-z" flag for easy
production of 3D Shapefiles. Also tested that and can see no
problems so far.
I would really like to see those changes in GRASS 6.4.2 at the
latest, though. They do make my life a lot easier.
Ben
----- Original Message -----
> 2011/1/14 <svn_grass at osgeo.org>:
> > Author: benducke
> > Date: 2011-01-14 13:04:44 -0800 (Fri, 14 Jan 2011)
> > New Revision: 45036
> > Modified:
> >   grass/branches/develbranch_6/vector/v.out.ogr/main.c
> > Log: This commit contains some small bugfixes, code clean-ups and
> > two new feature for v.out.ogr.
> > 1. Fixed a but that would spawn ugly error messages in conjunction
> > with the "-s" flag
> > 2. Reduced the SQL SELECT statements to just one instead of one per
> > feature, increasing output speed by several magnitudes.
> > 3. Added a new "-z" flag, which provides a simple and robust means
> > of producing 3D ESRI Shapefiles
> > --> Please test intensively!
> please, could you use trunk as development branch and optionally
> backport the changes to devbr6? Devbr6 is intended to be a test-bed
> for relbr64 backports! Go for GRASS 7!
> Martin
> -- Martin Landa <landa.martin gmail.com> *
> http://geo.fsv.cvut.cz/~landa
Files attached to this email may be in ISO 26300 format (OASIS Open Document Format). If you have difficulty opening them, please visit http://iso26300.info for more information.
