[GRASS-dev] Re: [GRASS GIS] #1257: Georectifier is broken
GRASS GIS trac at osgeo.org
Sun Jan 16 06:16:58 EST 2011
 Reporter:  cmbarton      |       Owner:  grass-dev@…
     Type:  defect        |      Status:  new
 Priority:  blocker       |   Milestone:  6.4.1
Component:  wxGUI         |     Version:  unspecified
 Keywords:  georectifier  |    Platform:  Unspecified
      Cpu:  Unspecified   |
Comment(by hellik):
 Replying to [comment:5 cmbarton]:
 > Following up on William's information. When I originally wrote this, the
 regular display was used for the target map for GCP creation and
 management. Looking at the GUI docs, it looks like this has been rewritten
 to have side by side displays now, with a target map in one and source map
 in the other. Perhaps someone can verify this.
 > If this is correct, the error is in the creation of the target display.
 The GCP manager window opens if no target map is selected, as William
 says. But there is no target map displayed either. The regular map display
 no longer seems to act like a target map now. So the target map canvas is
 bombing.
 > William documents that this seems OK in GRASS 6.4.0 but confirms that it
 is broken in the dev versions, including 6.4.1. So this needs to be fixed
 before any other release. Has anyone checked Windows on this?
 > Michael
 tested with nightly-build WinGRASS-7.0.SVN-r45023-1-Setup.exe,
 georectifier is working (see screenshot). I will try later on a nightly
 wingrass6.4.1-build.
 best regards
 Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/1257#comment:6>
