[GRASS-dev] Re: [GRASS GIS] #1257: Georectifier is broken
GRASS GIS trac at osgeo.org
Sun Jan 16 11:04:58 EST 2011
 Reporter:  cmbarton      |       Owner:  grass-dev@…
     Type:  defect        |      Status:  new
 Priority:  blocker       |   Milestone:  6.4.1
Component:  wxGUI         |     Version:  unspecified
 Keywords:  georectifier  |    Platform:  MacOSX
      Cpu:  OSX/Intel     |
Changes (by cmbarton):
  * platform:  Unspecified => MacOSX
  * cpu:  Unspecified => OSX/Intel
Comment:
 Thanks Helmut.
 Helmut tried an alternate way of getting a target map that neither William
 nor I tried (image ending in 144249). When I replicate what he did in
 GRASS 6.5, I do not get a target map. The georectifier does not crash, but
 I get the same error as I reported above (and no target map).
 self.height is not getting set. I'm not sure where this variable is coming
 from in the current version of the code. Does this variable get used in
 any other code than the GUI? If not, then we need to look at how its value
 is being acquired. If yes, then it is the way it is being used in this
 case--perhaps switching locations (from xy back to target) is not working
 right.
 I'm happy to do some testing, but don't have time right now to completely
 reverse engineer the new code and so could use help in this.
 Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/1257#comment:9>
