[GRASS-dev] Re: [GRASS GIS] #1257: Georectifier is broken
trac at osgeo.org
Mon Jan 17 08:57:59 EST 2011
Reporter: cmbarton | Owner: grass-dev@…
Type: defect | Status: new
Priority: blocker | Milestone: 6.4.1
Component: wxGUI | Version: unspecified
Keywords: georectifier | Platform: MacOSX
Cpu: OSX/Intel |
Comment(by mmetz):
Replying to [comment:11 cmbarton]:
> I found where the error is and can prevent it. But I don't yet know why
this is a problem. Hopefully Markus M will have some ideas. The errors are
generated by...[[BR]]
> self.OnZoomToMap(None) in line 870
First case, a target map is specified when starting the georectifier:
in trunk, gcpmapdisp.py L309 I have commented out a call to update the AUI
Manager. That line was active in the original georectifer and may be
needed on Mac. On msys however, activating this line causes havoc. On
Linux, it does not matter.
> and a similar call of ...
> self.parent.TgtMapWindow.ZoomToMap(layers =
self.parent.TgtMap.GetListOfLayers()) in line 2739
Second case, the georectifier is started with a source map only and a
target map is specified later on through the settings dialog:
in trunk, gcpmanager.py, you can try to move lines 2745 and 2753 up by 3
lines and insert them right after self.parent._mgr.GetPane(). The target
map window (and its size) would now be updated by the AUI Manager before
any call to ZoomToMap. Moving these lines does apparently not matter under
msys or Linux.
Markus M
Ticket URL: <http://trac.osgeo.org/grass/ticket/1257#comment:15>
