[GRASS-dev] r45069 -
grass/branches/develbranch_6/general/g.findfile - compiling error
Helmut Kudrnovsky
hellik at web.de
Mon Jan 17 15:26:08 EST 2011
grass65 self compiled in osgeo4w-stack at r45069
there is following compiling error
GRASS GIS compilation log
Started compilation: Mon Jan 17 18:46:45 GMT 2011
Errors in:
/c/osgeo4w/usr/src/grass6_devel/general/g.findfile
In case of errors please change into the directory with error and run 'make'.
If you get multiple errors, you need to deal with them in the order they
appear in the error log. If you get an error building a library, you will
also get errors from anything which uses the library.
Finished compilation: Mon Jan 17 20:17:45 GMT 2011
syringia at NADA /c/osgeo4w/usr/src/grass6_devel/general/g.findfile
$ make
../../include/Make/Module.make:25: warning: overriding commands for target `install'
../../include/Make/Rules.make:90: warning: ignoring old commands for target `install'
gcc -L/c/osgeo4w/usr/src/grass6_devel/dist.i686-pc-mingw32/lib -Wl,--export-dynamic,--enable-runtime-pseudo-reloc -L/c/OSGeo4W/apps/gdal-16/lib -L/c/OSGeo4W/lib -o /c/osgeo4w/usr/src/grass6_devel/dist.i686-pc-mingw32/bin/g.findfile.exe OBJ.i686-pc-mingw32/main.o ../../lib/gis/OBJ.i686-pc-mingw32/fmode.o -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lintl -lxdr -liberty -lws2_32 -lz
OBJ.i686-pc-mingw32/main.o: In function `main':
c:/osgeo4w/usr/src/grass6_devel/general/g.findfile/main.c:100: undefined reference to `G_unqualified_name'
collect2: ld returned 1 exit status
make: *** [/c/osgeo4w/usr/src/grass6_devel/dist.i686-pc-mingw32/bin/g.findfile.exe] Error 1
best regards
Helmut
___________________________________________________________
NEU: FreePhone - kostenlos mobil telefonieren und surfen!
Jetzt informieren: http://produkte.web.de/go/webdefreephone
Type: application/pkcs7-signature
Desc: S/MIME Cryptographic Signature
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20110117/9c04c667/smime.bin
