[GRASS-dev] Re: [GRASS GIS] #1262: r.proj broken in all dev versions
GRASS GIS trac at osgeo.org
Fri Jan 21 03:16:11 EST 2011
 Reporter:  cmbarton      |       Owner:  grass-dev@…
     Type:  defect        |      Status:  new
 Priority:  blocker       |   Milestone:  6.4.1
Component:  Raster        |     Version:  unspecified
 Keywords:  reprojection  |    Platform:  MacOSX
      Cpu:  OSX/Intel     |
Comment(by mlennert):
 Replying to [comment:2 cmbarton]:
 > I've tested this and on the Mac at least r.proj is broken in all
 development versions: 7.0, 6.5, and 6.4.1. Here is the result from testing
 it on the North Carolina demo data set, trying to reproject from State
 Plane into Latlon (same thing happens going the other way).
 > There is a segmentation fault and no map is reprojected.
 > r.proj input=aspect location=nc_spm_07 mapset=PERMANENT
 > Input Projection Parameters:  +proj=lcc +lat_1=36.16666666666666
 +lat_2=34.33333333333334 +lat_0=33.75 +lon_0=-79 +x_0=609601.22 +y_0=0
 +no_defs +a=6378137 +rf=298.257222101 +towgs84=0.000,0.000,0.000
 > Input Unit Factor: 1
 > Output Projection Parameters:  +proj=longlat +a=6378137
 +rf=298.257223563 +no_defs
 > Output Unit Factor: 1
 > Segmentation fault
 I've just tried to reproduce on Debian GNU/Linux using fairly recent
 grass7 and grass65, but I don't get any segmentation fault and
 reprojection works well.
 Moritz
Ticket URL: <http://trac.osgeo.org/grass/ticket/1262#comment:3>
