[GRASS-dev] Re: [GRASS GIS] #1262: r.proj broken in all dev versions
GRASS GIS trac at osgeo.org
Fri Jan 21 04:07:30 EST 2011
 Reporter:  cmbarton              |       Owner:  grass-dev@…
     Type:  defect                |      Status:  new
 Priority:  blocker               |   Milestone:  6.4.1
Component:  Raster                |     Version:  unspecified
 Keywords:  r.proj, reprojection  |    Platform:  MacOSX
      Cpu:  OSX/Intel             |
Comment(by neteler):
 Replying to [comment:2 cmbarton]:
 > There is a segmentation fault and no map is reprojected.
 > r.proj input=aspect location=nc_spm_07 mapset=PERMANENT
 > Input Projection Parameters:  +proj=lcc +lat_1=36.16666666666666
 +lat_2=34.33333333333334 +lat_0=33.75 +lon_0=-79 +x_0=609601.22 +y_0=0
 +no_defs +a=6378137 +rf=298.257222101 +towgs84=0.000,0.000,0.000
 > Input Unit Factor: 1
 > Output Projection Parameters:  +proj=longlat +a=6378137
 +rf=298.257223563 +no_defs
 > Output Unit Factor: 1
 > Segmentation fault
 Michael, please use a debugger and add the backtrace to the ticket.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1262#comment:5>
