[GRASS-dev] [GRASS GIS] #1266: d.vect has problems
GRASS GIS trac at osgeo.org
Mon Jan 24 04:26:21 EST 2011
 Reporter:  akbgf    |       Owner:  grass-dev@…
     Type:  defect   |      Status:  new
 Priority:  normal   |   Milestone:  7.0.0
Component:  Display  |     Version:  svn-trunk
 Keywords:  d.vect   |    Platform:  Linux
      Cpu:  x86-32   |
 Hi!
 If using any selection option of d.vect (the list of category values or
 the where condition) GRASS-7.0 does not display the vector. The problem
 was in r45123 and is still there in r45168.
 If I start with no selection option except feature type selection, vectors
 are displayed. If I turn on a selection option of a vector - either the
 category list or the where condition, the vector is not displayed, other
 vectors are visible. After turning off the selection option, the vector is
 still non-visible. I tried to turn the vector on and off in the Layer
 Manager window and re-render map display - no effect. The vector is still
 there - I see the info of vector elements using v.what, however the vector
 is non-visible. I tested this problem on three different vectors having
 only areas, only lines, and only points.
 An early version of GRASS-7 (of Dec 15 or 16, I guess) does not have this
 problem.
 Andres Kuusk, Tartu Observatory, Estonia
Ticket URL: <http://trac.osgeo.org/grass/ticket/1266>
