[GRASS-dev] Re: [GRASS GIS] #699: v.buffer segfault: in
Vect_get_isle_points()
trac at osgeo.org
Tue Jan 25 07:22:52 EST 2011
#699: v.buffer segfault: in Vect_get_isle_points()
Reporter: neteler | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Vector | Version: 6.4.0 RCs
Keywords: v.buffer | Platform: All
Cpu: All |
Changes (by mmetz):
* milestone: 6.4.0 => 7.0.0
Comment:
Replying to [comment:7 mlennert]:
> Replying to [comment:5 mmetz]:
> > The segfault is fixed in 6.4 r38554, but the other problems remain.
> I still get a segfault in all three version (6.4, 6.5 and trunk). In
6.4:
> v.generalize railroads out=rail_simple method=douglas_reduction
reduction=20
> v.buffer rail_simple dist=1000 out=rail1000
This is unfortunately a different bug in v.buffer, happening in pg_create
in dgraph.c. The original bug reported in this ticket happened only when
buffering areas, whereas in this case lines are buffered and a different
bug has been detected.
I am changing Milestone because these bugs probably don't get fixed in
6.4.x.
Markus M
Ticket URL: <http://trac.osgeo.org/grass/ticket/699#comment:8>
