[GRASS-dev] [GRASS GIS] #1268: r.out.vtk does not work as desired for RGB images
GRASS GIS trac at osgeo.org
Tue Jan 25 16:50:08 EST 2011
 Reporter:  voncasec     |       Owner:  grass-dev@…
     Type:  enhancement  |      Status:  new
 Priority:  normal       |   Milestone:  6.4.1
Component:  Default      |     Version:  svn-releasebranch64
 Keywords:  vtk          |    Platform:  Linux
      Cpu:  x86-64       |
 r.out.vtk does not allow a user to export an RGB series of images to vtk
 format without specifying a required image as well.
 For example, running r.out.vtk for an rgb series, as described in the user
 manual, returns the follwing:
 r.out.vtk rgbmaps=Landsat_NIR,Landsat_Red,Landsat_Green
 elevation=elevation.10m output=/tmp/out.vtk
 ERROR:
 Parameter 'input' (Name of input raster map(s)) is missing.
 Running r.out.vtk for an rgb series as described below creates the VTK
 file, but it is not viewable as an RGB image in Mayavi.
 r.out.vtk input=FCIR_Composite
 rgbmaps=Landsat_NIR,Landsat_Red,Landsat_Green elevation=elevation.10m
 output=/tmp/out.vtk
 To create the image for viewing in Mayavi, I currently have to convert the
 image channels to rast3d layers (r.to.rast3), then export to vtk using the
 r3.out.vtk option
 r3.out.vtk top=elevation.10m bottom=elevation.10m
 rgbmaps=rgbmaps=Landsat_NIR,Landsat_Red,Landsat_Green output=/tmp/out.vtk
 Can the required option be changed with r.out.vtk so that it will not
 prevent a user from exporting RGB channels only to vtk.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1268>
