[GRASS-dev] Re: [GRASS GIS] #1178: WinGrass: g.extension - problem
with path to $GISBASE
trac at osgeo.org
Wed Jan 26 10:05:56 EST 2011
#1178: WinGrass: g.extension - problem with path to $GISBASE
Reporter: hellik | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 6.4.1
Component: Installation | Version: svn-releasebranch64
Keywords: wingrass, g.extension, path, installation, addons | Platform: MSWindows Vista
Cpu: x86-32 |
Comment(by hellik):
Replying to [comment:27 hellik]:
> Replying to [comment:26 hellik]:
> gcc.exe: installation problem, cannot exec `cc1': No suchfile or
directory
> what does this mean?
> Helmut
these exes are in C:\OSGeo4W\libexec\gcc\mingw32\3.4.5 and not packed into
the wingrass-installer.
if I put these files in C:\Program Files\GRASS 6.5.SVN\extrabin
there is following result
(Wed Jan 26 16:02:04 2011)
g.extension --verbose extension=i.landsat.toar
svnurl=https://svn.osgeo.org/grass/grass-addons
Using WGET for downloading data.
Fetching <i.landsat.toar> from GRASS-Addons SVN (be patient)...
A i.landsat.toar\landsat_set.c
A i.landsat.toar\local_proto.h
A i.landsat.toar\main.c
A i.landsat.toar\description.html
A i.landsat.toar\landsat.c
A i.landsat.toar\earth_sun.c
A i.landsat.toar\landsat.h
A i.landsat.toar\landsat_met.c
A i.landsat.toar\Makefile
A i.landsat.toar\earth_sun.h
U i.landsat.toar
Checked out revision 45194.
Compiling <i.landsat.toar>...
C:/PROGRA~1/GRASS6~1.SVN/include/Make/Module.make:25:
warning: overriding commands for target `install'
C:/PROGRA~1/GRASS6~1.SVN/include/Make/Rules.make:90:
warning: ignoring old commands for target `install'
test -d OBJ.i686-pc-mingw32 || mkdir -p OBJ.i686-pc-mingw32
gcc -I/c/OSGeo4W/apps/grass/grass-6.5.svn/dist.i686-pc-mingw32/include
-I/c/OSGeo4W/apps/gdal-16/include -I/c/OSGeo4W/include -g -O2
-DPACKAGE=\""grassmods"\" -I/c/OSGeo4W/apps/grass/grass-6.5.svn/dist.i686
-pc-mingw32/include -o OBJ.i686-pc-mingw32/earth_sun.o -c earth_sun.c
In file included from earth_sun.c:25:
c:/OSGeo4W/include/stdio.h:26:20: stddef.h: No such file or
directory
c:/OSGeo4W/include/stdio.h:28:20: stdarg.h: No such file or
directory
c:/OSGeo4W/include/stdio.h:191: error: syntax error before
"size_t"
c:/OSGeo4W/include/stdio.h:207: error: syntax error before
"size_t"
c:/OSGeo4W/include/stdio.h:208: error: syntax error before
"__gnuc_va_list"
c:/OSGeo4W/include/stdio.h:209: error: syntax error before
"__gnuc_va_list"
c:/OSGeo4W/include/stdio.h:210: error: syntax error before
"__gnuc_va_list"
c:/OSGeo4W/include/stdio.h:211: error: syntax error before
"size_t"
c:/OSGeo4W/include/stdio.h:296: error: syntax error before
"__gnuc_va_list"
c:/OSGeo4W/include/stdio.h:297: error: syntax error before
"__gnuc_va_list"
c:/OSGeo4W/include/stdio.h:298: error: syntax error before
"__gnuc_va_list"
c:/OSGeo4W/include/stdio.h:311: error: syntax error before
"__gnuc_va_list"
c:/OSGeo4W/include/stdio.h:312: error: syntax error before
"__gnuc_va_list"
c:/OSGeo4W/include/stdio.h:313: error: syntax error before
"__gnuc_va_list"
c:/OSGeo4W/include/stdio.h:319: error: syntax error before
"size_t"
c:/OSGeo4W/include/stdio.h:320: error: syntax error before
"size_t"
c:/OSGeo4W/include/stdio.h:330: error: syntax error before
"size_t"
c:/OSGeo4W/include/stdio.h:330: warning: conflicting types
for built-in function 'snprintf'
c:/OSGeo4W/include/stdio.h:331: error: syntax error before
"size_t"
c:/OSGeo4W/include/stdio.h:333: error: syntax error before
"__gnuc_va_list"
c:/OSGeo4W/include/stdio.h:335: error: syntax error before
"__gnuc_va_list"
c:/OSGeo4W/include/stdio.h:337: error: syntax error before
"__gnuc_va_list"
c:/OSGeo4W/include/stdio.h:411: warning: `__cdecl__'
attribute only applies to function types
c:/OSGeo4W/include/stdio.h:411: warning: `__nothrow__'
attribute ignored
c:/OSGeo4W/include/stdio.h:411: error: syntax error before
"fread"
c:/OSGeo4W/include/stdio.h:412: warning: `__cdecl__'
c:/OSGeo4W/include/stdio.h:412: warning: `__nothrow__'
attribute ignored
c:/OSGeo4W/include/stdio.h:412: error: syntax error before
"fwrite"
c:/OSGeo4W/include/stdio.h:562: error: syntax error before
'*' token
c:/OSGeo4W/include/stdio.h:563: error: syntax error before
'*' token
c:/OSGeo4W/include/stdio.h:564: error: syntax error before
'*' token
c:/OSGeo4W/include/stdio.h:565: error: syntax error before
'*' token
c:/OSGeo4W/include/stdio.h:566: error: syntax error before
'*' token
c:/OSGeo4W/include/stdio.h:567: error: syntax error before
'*' token
c:/OSGeo4W/include/stdio.h:568: error: syntax error before
'*' token
c:/OSGeo4W/include/stdio.h:569: error: syntax error before
'*' token
c:/OSGeo4W/include/stdio.h:570: error: syntax error before
'*' token
c:/OSGeo4W/include/stdio.h:571: warning: `__cdecl__'
c:/OSGeo4W/include/stdio.h:571: warning: `__nothrow__'
attribute ignored
c:/OSGeo4W/include/stdio.h:571: error: syntax error before
"fgetwc"
c:/OSGeo4W/include/stdio.h:572: warning: `__cdecl__'
c:/OSGeo4W/include/stdio.h:572: warning: `__nothrow__'
attribute ignored
c:/OSGeo4W/include/stdio.h:572: error: syntax error before
"fputwc"
c:/OSGeo4W/include/stdio.h:573: warning: `__cdecl__'
c:/OSGeo4W/include/stdio.h:573: warning: `__nothrow__'
attribute ignored
c:/OSGeo4W/include/stdio.h:573: error: syntax error before
"ungetwc"
c:/OSGeo4W/include/stdio.h:577: error: syntax error before
'*' token
c:/OSGeo4W/include/stdio.h:578: error: syntax error before
'*' token
c:/OSGeo4W/include/stdio.h:582: error: syntax error before
'*' token
'*' token
c:/OSGeo4W/include/stdio.h:582: warning: data definition has
no type or storage class
c:/OSGeo4W/include/stdio.h:583: error: syntax error before
'*' token
c:/OSGeo4W/include/stdio.h:584: warning: `__cdecl__'
c:/OSGeo4W/include/stdio.h:584: warning: `__nothrow__'
attribute ignored
c:/OSGeo4W/include/stdio.h:584: error: syntax error before
"getwc"
c:/OSGeo4W/include/stdio.h:585: warning: `__cdecl__'
c:/OSGeo4W/include/stdio.h:585: warning: `__nothrow__'
attribute ignored
c:/OSGeo4W/include/stdio.h:585: error: syntax error before
"getwchar"
c:/OSGeo4W/include/stdio.h:586: error: syntax error before
'*' token
c:/OSGeo4W/include/stdio.h:586: warning: data definition has
c:/OSGeo4W/include/stdio.h:587: warning: `__cdecl__'
c:/OSGeo4W/include/stdio.h:587: warning: `__nothrow__'
attribute ignored
c:/OSGeo4W/include/stdio.h:587: error: syntax error before
"putwc"
c:/OSGeo4W/include/stdio.h:588: error: syntax error before
'*' token
c:/OSGeo4W/include/stdio.h:589: warning: `__cdecl__'
c:/OSGeo4W/include/stdio.h:589: warning: `__nothrow__'
attribute ignored
c:/OSGeo4W/include/stdio.h:589: error: syntax error before
"putwchar"
c:/OSGeo4W/include/stdio.h:590: error: syntax error before
'*' token
c:/OSGeo4W/include/stdio.h:591: error: syntax error before
'*' token
c:/OSGeo4W/include/stdio.h:592: error: syntax error before
'*' token
c:/OSGeo4W/include/stdio.h:593: error: syntax error before
'*' token
c:/OSGeo4W/include/stdio.h:594: error: syntax error before
'*' token
'*' token
c:/OSGeo4W/include/stdio.h:594: warning: data definition has
c:/OSGeo4W/include/stdio.h:595: error: syntax error before
'*' token
'*' token
c:/OSGeo4W/include/stdio.h:595: warning: data definition has
c:/OSGeo4W/include/stdio.h:596: error: syntax error before
'*' token
c:/OSGeo4W/include/stdio.h:597: error: syntax error before
'*' token
c:/OSGeo4W/include/stdio.h:598: error: syntax error before
'*' token
c:/OSGeo4W/include/stdio.h:599: error: syntax error before
'*' token
c:/OSGeo4W/include/stdio.h:603: error: syntax error before
'*' token
c:/OSGeo4W/include/stdio.h:605: error: syntax error before
'*' token
c:/OSGeo4W/include/stdio.h: In function `vsnwprintf':
c:/OSGeo4W/include/stdio.h:606: error: `s' undeclared (first
use in this function)
c:/OSGeo4W/include/stdio.h:606: error: (Each undeclared
identifier is reported only once
c:/OSGeo4W/include/stdio.h:606: error: for each function it
appears in.)
c:/OSGeo4W/include/stdio.h:606: error: `n' undeclared (first
c:/OSGeo4W/include/stdio.h:606: error: `format' undeclared
(first use in this function)
c:/OSGeo4W/include/stdio.h:606: error: `arg' undeclared
c:/OSGeo4W/include/stdio.h: At top level:
c:/OSGeo4W/include/stdio.h:607: error: syntax error before
'*' token
c:/OSGeo4W/include/stdio.h:609: error: syntax error before
'*' token
c:/OSGeo4W/include/stdio.h:610: error: syntax error before
'*' token
c:/OSGeo4W/include/stdio.h:620: error: syntax error before
'*' token
c:/OSGeo4W/include/stdio.h:627: warning: `__cdecl__'
c:/OSGeo4W/include/stdio.h:627: warning: `__nothrow__'
attribute ignored
c:/OSGeo4W/include/stdio.h:627: error: syntax error before
"_fgetwchar"
c:/OSGeo4W/include/stdio.h:628: warning: `__cdecl__'
c:/OSGeo4W/include/stdio.h:628: warning: `__nothrow__'
attribute ignored
c:/OSGeo4W/include/stdio.h:628: error: syntax error before
"_fputwchar"
c:/OSGeo4W/include/stdio.h:633: warning: `__cdecl__'
c:/OSGeo4W/include/stdio.h:633: warning: `__nothrow__'
attribute ignored
c:/OSGeo4W/include/stdio.h:633: error: syntax error before
"fgetwchar"
c:/OSGeo4W/include/stdio.h:634: warning: `__cdecl__'
c:/OSGeo4W/include/stdio.h:634: warning: `__nothrow__'
attribute ignored
c:/OSGeo4W/include/stdio.h:634: error: syntax error before
"fputwchar"
In file included from earth_sun.c:26:
c:/OSGeo4W/include/stdlib.h:79: error: syntax error before
'*' token
c:/OSGeo4W/include/stdlib.h:79: warning: data definition has
c:/OSGeo4W/include/stdlib.h:150: error: syntax error before
'*' token
c:/OSGeo4W/include/stdlib.h:150: warning: data definition
has no type or storage class
c:/OSGeo4W/include/stdlib.h:262: error: syntax error before
'*' token
c:/OSGeo4W/include/stdlib.h:262: warning: data definition
c:/OSGeo4W/include/stdlib.h:307: error: syntax error before
'*' token
c:/OSGeo4W/include/stdlib.h:308: error: syntax error before
'*' token
c:/OSGeo4W/include/stdlib.h:333: error: syntax error before
'*' token
c:/OSGeo4W/include/stdlib.h:334: error: syntax error before
'*' token
c:/OSGeo4W/include/stdlib.h:335: error: syntax error before
'*' token
c:/OSGeo4W/include/stdlib.h:337: error: syntax error before
'*' token
c:/OSGeo4W/include/stdlib.h:338: error: syntax error before
'*' token
c:/OSGeo4W/include/stdlib.h:341: error: syntax error before
'*' token
'*' token
c:/OSGeo4W/include/stdlib.h:341: warning: data definition
c:/OSGeo4W/include/stdlib.h:342: error: syntax error before
'*' token
c:/OSGeo4W/include/stdlib.h:343: error: syntax error before
'*' token
c:/OSGeo4W/include/stdlib.h:344: error: syntax error before
'*' token
c:/OSGeo4W/include/stdlib.h:345: error: syntax error before
'*' token
c:/OSGeo4W/include/stdlib.h:346: error: syntax error before
'*' token
c:/OSGeo4W/include/stdlib.h:347: error: syntax error before
'*' token
'*' token
c:/OSGeo4W/include/stdlib.h:347: warning: data definition
c:/OSGeo4W/include/stdlib.h:352: warning: `__cdecl__'
c:/OSGeo4W/include/stdlib.h:352: warning: `__nothrow__'
attribute ignored
c:/OSGeo4W/include/stdlib.h:352: error: syntax error before
"wcstombs"
c:/OSGeo4W/include/stdlib.h:353: error: syntax error before
"wchar_t"
c:/OSGeo4W/include/stdlib.h:355: error: syntax error before
"size_t"
c:/OSGeo4W/include/stdlib.h:356: warning: `__cdecl__'
c:/OSGeo4W/include/stdlib.h:356: warning: `__nothrow__'
attribute ignored
c:/OSGeo4W/include/stdlib.h:356: error: syntax error before
"mbstowcs"
c:/OSGeo4W/include/stdlib.h:357: error: syntax error before
'*' token
c:/OSGeo4W/include/stdlib.h:362: warning: parameter names
(without types) in function declaration
c:/OSGeo4W/include/stdlib.h:363: warning: parameter names
c:/OSGeo4W/include/stdlib.h:364: error: syntax error before
"size_t"
c:/OSGeo4W/include/stdlib.h:376: error: syntax error before
"size_t"
c:/OSGeo4W/include/stdlib.h:377: error: syntax error before
')' token
c:/OSGeo4W/include/stdlib.h:378: error: syntax error before
"size_t"
c:/OSGeo4W/include/stdlib.h:379: error: syntax error before
')' token
c:/OSGeo4W/include/stdlib.h:425: error: syntax error before
"size_t"
c:/OSGeo4W/include/stdlib.h:430: error: syntax error before
'*' token
"wchar_t"
c:/OSGeo4W/include/stdlib.h:430: warning: data definition
c:/OSGeo4W/include/stdlib.h:431: error: syntax error before
'*' token
"wchar_t"
c:/OSGeo4W/include/stdlib.h:431: warning: data definition
c:/OSGeo4W/include/stdlib.h:432: error: syntax error before
'*' token
"wchar_t"
c:/OSGeo4W/include/stdlib.h:432: warning: data definition
c:/OSGeo4W/include/stdlib.h:438: error: syntax error before
'*' token
c:/OSGeo4W/include/stdlib.h:439: error: syntax error before
'*' token
"wchar_t"
c:/OSGeo4W/include/stdlib.h:439: warning: data definition
c:/OSGeo4W/include/stdlib.h:440: error: syntax error before
'*' token
"wchar_t"
c:/OSGeo4W/include/stdlib.h:440: warning: data definition
c:/OSGeo4W/include/stdlib.h:525: error: syntax error before
'*' token
c:/OSGeo4W/include/stdlib.h:528: error: syntax error before
'*' token
"wchar_t"
c:/OSGeo4W/include/stdlib.h:528: warning: data definition
c:/OSGeo4W/include/stdlib.h:529: error: syntax error before
'*' token
"wchar_t"
c:/OSGeo4W/include/stdlib.h:529: warning: data definition
c:/OSGeo4W/include/stdlib.h:538: error: syntax error before
'*' token
c:/OSGeo4W/include/stdlib.h: In function `wtoll':
c:/OSGeo4W/include/stdlib.h:539: error: `_w' undeclared
c:/OSGeo4W/include/stdlib.h: At top level:
c:/OSGeo4W/include/stdlib.h:540: error: syntax error before
'*' token
"wchar_t"
c:/OSGeo4W/include/stdlib.h: In function `lltow':
c:/OSGeo4W/include/stdlib.h:541: error: `_n' undeclared
c:/OSGeo4W/include/stdlib.h:541: error: `_w' undeclared
c:/OSGeo4W/include/stdlib.h:541: error: `_i' undeclared
c:/OSGeo4W/include/stdlib.h:542: error: syntax error before
'*' token
"wchar_t"
c:/OSGeo4W/include/stdlib.h: In function `ulltow':
c:/OSGeo4W/include/stdlib.h:543: error: `_n' undeclared
c:/OSGeo4W/include/stdlib.h:543: error: `_w' undeclared
c:/OSGeo4W/include/stdlib.h:543: error: `_i' undeclared
In file included from earth_sun.c:27:
c:/OSGeo4W/include/string.h: At top level:
c:/OSGeo4W/include/string.h:36: error: syntax error before
"size_t"
c:/OSGeo4W/include/string.h:37: error: syntax error before
"size_t"
c:/OSGeo4W/include/string.h:38: error: syntax error before
"size_t"
c:/OSGeo4W/include/string.h:39: error: syntax error before
"size_t"
c:/OSGeo4W/include/string.h:40: error: syntax error before
"size_t"
c:/OSGeo4W/include/string.h:46: warning: `__cdecl__'
c:/OSGeo4W/include/string.h:46: warning: `__nothrow__'
attribute ignored
c:/OSGeo4W/include/string.h:46: error: syntax error before
"strcspn"
c:/OSGeo4W/include/string.h:49: warning: `__cdecl__'
c:/OSGeo4W/include/string.h:49: warning: `__nothrow__'
attribute ignored
c:/OSGeo4W/include/string.h:49: error: syntax error before
"strlen"
c:/OSGeo4W/include/string.h:50: error: syntax error before
"size_t"
c:/OSGeo4W/include/string.h:51: error: syntax error before
"size_t"
c:/OSGeo4W/include/string.h:52: error: syntax error before
"size_t"
c:/OSGeo4W/include/string.h:55: warning: `__cdecl__'
c:/OSGeo4W/include/string.h:55: warning: `__nothrow__'
attribute ignored
c:/OSGeo4W/include/string.h:55: error: syntax error before
"strspn"
c:/OSGeo4W/include/string.h:58: warning: `__cdecl__'
c:/OSGeo4W/include/string.h:58: warning: `__nothrow__'
attribute ignored
c:/OSGeo4W/include/string.h:58: error: syntax error before
"strxfrm"
c:/OSGeo4W/include/string.h:65: error: syntax error before
"size_t"
c:/OSGeo4W/include/string.h:66: error: syntax error before
"size_t"
c:/OSGeo4W/include/string.h:72: error: syntax error before
"size_t"
c:/OSGeo4W/include/string.h:73: error: syntax error before
"size_t"
c:/OSGeo4W/include/string.h:77: error: syntax error before
"size_t"
c:/OSGeo4W/include/string.h:80: error: syntax error before
"size_t"
c:/OSGeo4W/include/string.h:81: error: syntax error before
"size_t"
c:/OSGeo4W/include/string.h:90: error: syntax error before
"size_t"
c:/OSGeo4W/include/string.h:91: error: syntax error before
"size_t"
c:/OSGeo4W/include/string.h:101: error: syntax error before
"size_t"
c:/OSGeo4W/include/string.h:102: error: syntax error before
"size_t"
c:/OSGeo4W/include/string.h:104: error: syntax error before
"size_t"
c:/OSGeo4W/include/string.h: In function `strncasecmp':
c:/OSGeo4W/include/string.h:105: error: `__sz1' undeclared
c:/OSGeo4W/include/string.h:105: error: `__sz2' undeclared
c:/OSGeo4W/include/string.h:105: error: `__sizeMaxCompare'
undeclared (first use in this function)
c:/OSGeo4W/include/string.h:106: error: syntax error before
"size_t"
c:/OSGeo4W/include/string.h:111: error: syntax error before
"size_t"
c:/OSGeo4W/include/string.h:122: error: syntax error before
'*' token
'*' token
c:/OSGeo4W/include/string.h:122: warning: data definition
c:/OSGeo4W/include/string.h:123: error: syntax error before
'*' token
'*' token
c:/OSGeo4W/include/string.h:123: warning: data definition
c:/OSGeo4W/include/string.h:124: error: syntax error before
'*' token
c:/OSGeo4W/include/string.h:125: error: syntax error before
'*' token
c:/OSGeo4W/include/string.h:126: error: syntax error before
'*' token
'*' token
c:/OSGeo4W/include/string.h:126: warning: data definition
c:/OSGeo4W/include/string.h:127: warning: `__cdecl__'
c:/OSGeo4W/include/string.h:127: warning: `__nothrow__'
attribute ignored
c:/OSGeo4W/include/string.h:127: error: syntax error before
"wcscspn"
c:/OSGeo4W/include/string.h:129: warning: `__cdecl__'
c:/OSGeo4W/include/string.h:129: warning: `__nothrow__'
attribute ignored
c:/OSGeo4W/include/string.h:129: error: syntax error before
"wcslen"
c:/OSGeo4W/include/string.h:130: error: syntax error before
'*' token
c:/OSGeo4W/include/string.h:130: warning: data definition
c:/OSGeo4W/include/string.h:131: error: syntax error before
'*' token
c:/OSGeo4W/include/string.h:132: error: syntax error before
'*' token
'*' token
c:/OSGeo4W/include/string.h:132: warning: data definition
c:/OSGeo4W/include/string.h:133: error: syntax error before
'*' token
'*' token
c:/OSGeo4W/include/string.h:133: warning: data definition
c:/OSGeo4W/include/string.h:134: error: syntax error before
'*' token
'*' token
c:/OSGeo4W/include/string.h:134: warning: data definition
c:/OSGeo4W/include/string.h:135: warning: `__cdecl__'
c:/OSGeo4W/include/string.h:135: warning: `__nothrow__'
attribute ignored
c:/OSGeo4W/include/string.h:135: error: syntax error before
"wcsspn"
c:/OSGeo4W/include/string.h:136: error: syntax error before
'*' token
c:/OSGeo4W/include/string.h:136: warning: data definition
c:/OSGeo4W/include/string.h:137: error: syntax error before
'*' token
'*' token
c:/OSGeo4W/include/string.h:137: warning: data definition
c:/OSGeo4W/include/string.h:138: warning: `__cdecl__'
c:/OSGeo4W/include/string.h:138: warning: `__nothrow__'
attribute ignored
c:/OSGeo4W/include/string.h:138: error: syntax error before
"wcsxfrm"
c:/OSGeo4W/include/string.h:148: error: syntax error before
'*' token
c:/OSGeo4W/include/string.h:148: warning: data definition
c:/OSGeo4W/include/string.h:149: error: syntax error before
'*' token
c:/OSGeo4W/include/string.h:150: error: syntax error before
'*' token
c:/OSGeo4W/include/string.h:151: error: syntax error before
'*' token
'*' token
c:/OSGeo4W/include/string.h:151: warning: data definition
c:/OSGeo4W/include/string.h:152: error: syntax error before
'*' token
c:/OSGeo4W/include/string.h:153: error: syntax error before
'*' token
'*' token
c:/OSGeo4W/include/string.h:153: warning: data definition
c:/OSGeo4W/include/string.h:154: error: syntax error before
'*' token
'*' token
c:/OSGeo4W/include/string.h:154: warning: data definition
c:/OSGeo4W/include/string.h:155: error: syntax error before
'*' token
'*' token
c:/OSGeo4W/include/string.h:155: warning: data definition
c:/OSGeo4W/include/string.h:156: error: syntax error before
'*' token
'*' token
c:/OSGeo4W/include/string.h:156: warning: data definition
c:/OSGeo4W/include/string.h:159: error: syntax error before
'*' token
c:/OSGeo4W/include/string.h:160: error: syntax error before
'*' token
c:/OSGeo4W/include/string.h:169: error: syntax error before
'*' token
c:/OSGeo4W/include/string.h:171: error: syntax error before
'*' token
c:/OSGeo4W/include/string.h: In function `wcscmpi':
c:/OSGeo4W/include/string.h:172: error: `__ws1' undeclared
c:/OSGeo4W/include/string.h:172: error: `__ws2' undeclared
c:/OSGeo4W/include/string.h:173: error: syntax error before
'*' token
'*' token
c:/OSGeo4W/include/string.h:173: warning: data definition
c:/OSGeo4W/include/string.h:174: error: syntax error before
'*' token
c:/OSGeo4W/include/string.h:175: error: syntax error before
'*' token
c:/OSGeo4W/include/string.h:176: error: syntax error before
'*' token
'*' token
c:/OSGeo4W/include/string.h:176: warning: data definition
c:/OSGeo4W/include/string.h:177: error: syntax error before
'*' token
c:/OSGeo4W/include/string.h:178: error: syntax error before
'*' token
'*' token
c:/OSGeo4W/include/string.h:178: warning: data definition
c:/OSGeo4W/include/string.h:179: error: syntax error before
'*' token
'*' token
c:/OSGeo4W/include/string.h:179: warning: data definition
c:/OSGeo4W/include/string.h:180: error: syntax error before
'*' token
'*' token
c:/OSGeo4W/include/string.h:180: warning: data definition
c:/OSGeo4W/include/string.h:181: error: syntax error before
'*' token
'*' token
c:/OSGeo4W/include/string.h:181: warning: data definition
make: *** [OBJ.i686-pc-mingw32/earth_sun.o] Error 1
ERROR: Compilation failed, sorry. Please check above error messages.
rm: cannot remove directory `C:\\gisdata\\grassdata/nc_spm_0
8/g65/.tmp/1580.0/i.landsat.toar': Permission denied
(Wed Jan 26 16:02:22 2011) Befehl ausgeführt (17 sec)
one step further, but the next issue ...
Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/1178#comment:28>
